| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Can't remove front axle
#2 (permalink) |
Staff
At work we use a tie rod pickle fork to butt up against the axle, then hit the pickle fork with a hammer. That gets the axle out of the diff. prying with pry bars just doesn't work very well. Its needs to have a solid, non-flexible direct hit.
As for the spindle end, put the nut back on the axle part way, and beat the hell out of it. Better to damage the $5 nut than the $150 axle. This is what we do as well, then beat the hell out of the nut and it usually backs the axle out.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
Tada! Okay, the nut trick worked great, after about 5 mighty wallops. Thanks!
I don't have a tie rod pickle fork. I'm not sure I understand the description. I assume you mean you are using it like a wedge - you fit it between the diff and the front drive shaft, at a tangent, and hit it so the wedge forces it apart. Not that you point the pickle fork straight in towards the axle. There's a relatively thin metal ring in here, and it seems like it would be easy to bend/damage if the pickle fork went straight in. I tried this with a chisel, but so far no success. I'm going to continue trying, but if anyone has any other suggestions, I'd like to hear them still. |
#4 (permalink) |
Staff
No don't use it like a wedge. Hold it at about a 45 degree angle against the axle and beat on it. The only reason I say pickle fork is because it is solid. Any thing that is solid will work, but pry bars are meant to be flexible.
__________________
#5 (permalink) |
You depending on the fork you might be able to get it to go around the axle??? I know they have different sizes (I think
) You could use anything that will not give much. A few good whacks and your on your way. If that does not work get a bigger hammer!
__________________
"""The Official Unofficial build thread!""" 92 std cab 22RE 5 spd 4x4 268 Engnbldr Cam 3"Intake w/ cone 31X10.5----4.10's Purchased 11/08 @125K miles Great find first project Toy 95 SR5 4Runner 3.Slow Auto :-( 4x4 (5 spd someday) 33X12.50----4.88's LC Coils She's raked a bit now 5/09 Traded a 1980 CB 750 for it!!! Yeah for me... 106K miles IFS Club #2 |
#6 (permalink) |
Well, I'm using a very heavy sledge hammer. I've tried with a piton (blunt piece of metal), hitting as hard as I can in the space, to no avail. This is on jack stands, not a lift, so I can't get a great swing. I've also tried a pretty long/heavy framing hammer. Sounds like I just have to keep at it.
#7 (permalink) |
Ok gotta ask, you do have all the bolts out??? Didn't forget one?
![]() Just a thought...
__________________
#8 (permalink) |
All the bolts out? On the diff? The FSM nor Haynes say anything about it. The steps in the FSM are:
Remove wheel Drain diff oil Remove axle hub nut remove speed sensor separate tie rod remove 2 bolts from lower arm remove inner drive shaft using sliding hammer It's the same in the Haynes manual. I think I saw mention of bolts on the diff in the older gen 4runner threads. If so, I don't think we have to do this on 4th gen. OTOH, if you meant the bolts on the LCA, yes, they are gone. |
#9 (permalink) |
Staff
There are no bolts holding the axle in to the diff. Its merely a C-clip, just like on the 3rd gens.
If you are removing bolts from the diff, you are doing something wrong.
__________________
#10 (permalink) |
I was thinking they are setup more like a 2nd gen with the front end IFS. I guess I assumed wrong. My bad...
__________________
#11 (permalink) |
And we are done! I took a cold chisel, ground off the sharp edge, and used that against the indentations in the axle assembly case. I think what was holding me up is that I was told there was just a c clip that needed to be released, and it would slide out. So I thought there would be a single pop and it would come out. Instead I had to drive it out bit by bit - it would move some, but still be attached.
Thanks to everyone for helping me out. I have to say, this would be a bear on the trail. The part everyone frets about, removing the hub nut, was easy. But getting that axle out (both ends) required a sledge - a long framing hammer didn't begin to touch it. |
#12 (permalink) |
Well I'm glad you got her out!!! I bet you feel better now!!
__________________
#13 (permalink) |
Yes. I haven't heard back from the guy with the reman axle, who was supposed to have called me by now. I have a feeling that I'm going to be buying a boot repair kit from the dealer, which is not a big deal. I need to learn how to do this stuff anyway.
| Tags |
| 4runner, 82, axle, axles, clips, drive, front, hard, hub, nut, remove, shaft, straight, toyota, wedge |
