A/C Promblem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-01-2006, 09:56 AM   #1 (permalink)
Bigvick's Avatar
Exclamation A/C Promblem
A good friend of mine has an '03 4Runner and he is having a promblem with his A/C. When he turns it on the light flashes(I guess he means the light on the button) and doesn't blow any cold air. Has anyone had this happen? What should we possibly look for or check? Could it show up something on a code reader? Any help will be greatly appreciated, he is trying to keep from going to the dealership.
__________________
Your only lost if you admit it!
'00 4runner SR5 4wd V6 (no mods yet)
'97 Tacoma r-cab 4wd 2.7L
Other toys-'05 Honda foreman 500 4wd (my ride)
'00 Polaris magnum 325 2wd (wife's ride)
Bigvick is offline
Old 03-01-2006, 09:59 AM   #2 (permalink)
Take it in to the dealership if it is still in warranty. I remember reading that a switch has bad contacts which causes this phenomenon. A certain batch of these switches goes bad and it'll need to be replaced..
Sharp4runr is offline
Old 03-01-2006, 10:09 AM   #3 (permalink)
Bigvick's Avatar
It's not under warranty anymore. Could that show up on a code reader?
__________________
Bigvick is offline
Old 03-01-2006, 10:49 AM   #4 (permalink)
Check out this page: http://experts.about.com/q/Toyota-Re...ght-blinks.htm
Did a search for "toyota a/c blinks" in google. If it is in fact covered by a TSB (Technical Service Bulletin) then you may get the repair for free or at a nominal cost. TSBs are repairs that Toyota will do if the problem is brought up, but is not treated like a Recall where they notify owners. They will only fix if your vehicle exhibits the problem.
Hope that helps...
Old 03-01-2006, 11:51 AM   #5 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
I believe you should be able to take it into a Toyota dealership for a quick diagnostic check without incurring any charges. This way you will know what you are battling against and can decide at that point what you want to do. So with that in mind, just drop it off at the closest dealer (I'm not too fond of this either but it's one of those deals you just gotta) and have them inspect to see what the problem may be. If it is indeed a TSB then they will do the repair for you (even if it's out of the warranty I believe).
Good luck
Good Times is offline
Old 03-01-2006, 02:39 PM   #6 (permalink)
Nic
Nic's Avatar
I have an 84 Camry and it has done that a few times. I have no clue as to why, but the AC button will start blinking and it will not work. I assumed that it had something to do with the compressor, but was never sure. If I remember correctly, after turning off the engine and starting it back up, it would work.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Old 03-02-2006, 04:11 AM   #7 (permalink)
Bigvick's Avatar
Thanks everybody! I found 3 TSB's on the a/c system. One of them is for the relay which engages/disengages the magnetic clutches on the compressor and the sympton is a flashing a/c light and it will not work. The other 2 was for ice build up and for the blower fan not matching the speed that it's shown to be on. My buddy has made an appointment with his dealership Monday so we'll see how it goes.
__________________
Bigvick is offline
Old 03-30-2006, 03:57 PM   #8 (permalink)
Where is the A/C magnetic clutch relay located? Mine's blinking too!
__________________
2003 4runner Sport V8 4X4
2002 Tacoma SR5 V6 4X4
1994 Pickup 22RE
jjcobra99 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
head set promblem bballchrism Vehicle Audio & Home Entertainment 2 10-06-2006 05:31 PM
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
