AH64ID's 07 Taco Buildup - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-21-2007, 01:01 PM   #1 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Well the buildup has begun. Small so far, but begun it has. I picked the truck up last saturday, not 3 hours after climbing out of the cockpit from a 3 day flight up from Texas.
First thing to go in was the hourmeter. No there is really no good reason to have one, but I wanted one. I used a relay attached to the OEM oil pressure switch.
Then the Scangauge II went in. Its temporarily mounted on the steering column. I would like to put it somewhere else, thou I dont know where.
Then this morning the level kit went it. Its a two piece spacer kit from cornfedsuspensions. Dave normally sells a 2" kit, but I didnt want that much, so I had him machine the top plate spacer down to only provide .75" lift. The spacer setup is aluminim for the top plate spacer, and plastic for the spring spacer. Very nice quality kit. The instructions left a little to be desired, but I have emailed Dave with some suggestions.
Stock full droop
Stock on the left, spacers on the right.
All back together
CV angle at full droop. The top plate allows for .75" extra droop, which is very nice. The CV angle is fine at full droop.
Before and After
And a few poser shots...
More to follow.. in the plans are a custom front receiver, bypass oil filter, and several sets of lights (front and rear).
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 03-21-2007, 04:38 PM   #2 (permalink)
Send a message via AIM to justinh
That stance is how they should come, along with some 275/70/17 all terrains. Just my opinion.
justinh is offline
Old 03-21-2007, 04:40 PM   #3 (permalink)
AH64ID's Avatar
I agree on the stance.
I am stull unsure what tires I will run, I may stick with the 70 series if it allows more room for chains. I am already pretty sure I am going to have to run 1" wheel spacers up front to get my HD chains to clear the upper control arm.
__________________
-John
AH64ID is offline
Old 03-21-2007, 05:57 PM   #4 (permalink)
itsmeagain5789's Avatar
yea, that stance is perfect, 2 inches i think would be too much. o yea, do the rear set of lights first, i want to see how you do that. lol. i need some ideas. right now all i can think of is a bed bar with some lights
__________________
Ed
New rig - 2007 Silver Tacoma Double Cab 4x4 trd offroad, roofrack, tacoma weather mats, dealer alarm, bed/reverse lights, cb, Toytec 3 inch with 885's, aal's, dif drop, and shims
265/75/r16 cooper discover stt's on stock rim, custom made sliders, rear dif breather mod
Former rig (SOLD. she will be missed) -
95 4x4 4runner 3.0 auto 161,000 miles
ram off road grille guard and 2 pro comp 55 w lights.
1.5 inch rear springs from allpro offroad
32x11.50 bfg mud terrain(byebye gas mileage)
itsmeagain5789 is offline
Old 03-21-2007, 06:09 PM   #5 (permalink)
slosurfer's Avatar
Looks good and welcome back! Next remove the front mudflaps. I am going to remove mine and then trim my rear ones up a little. They hang so low and don't bend very well. That scangauge would be pretty trick in the back of the pull down compartment that is low and left of the steering wheel.
__________________
Chris
7th Annual Pismo Jamboree: Sept. 25-27, 2009
'93 4runner SR5 3.0 Auto 4WD
'07 Tacoma Dcab 4x4 TRD offroad
'89 F250 4x4 w/utility bed
M416 1/4 ton military trailer
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
Semper Fi
SLO 4wheelers
slosurfer is offline
Old 03-21-2007, 07:05 PM   #6 (permalink)
AH64ID's Avatar
I want to pull the flaps, but I dont want to mess up the sides of the truck...so ???
I thought about the SG down there, but too hard to read on the fwy.
__________________
-John
AH64ID is offline
Old 03-21-2007, 07:11 PM   #7 (permalink)
if you are going to remove the flaps do it soon, I waited about a year and mine left some scratches on the side of my flares where they wrap around a little. I have had mind off for awhile and not gotten any new scratches, the paint on the rockers is thicker and has the orange peel, with stock tires I wouldn't worry too much they aren't open enough to pick up rocks and stuff.
Spacers may be good for you since you could put them on only when you know you will need to use the chains and not run them otherwise.
justinh is offline
Old 03-21-2007, 08:55 PM   #8 (permalink)
AH64ID's Avatar
Quote:
Yeah thats what I figure, run them in the winter. I already have to run .25" spacers on my 92 for chains.
__________________
-John
AH64ID is offline
Old 03-22-2007, 07:02 AM   #9 (permalink)
Rivalred's Avatar
Do yourself and your beautiful vehicle a favor, get some WeatherTech Floor Liners for your truck. I had them and they worked very well.
www.weathertech.com
If you want some extra interior parts let me know. I still have the wiring for electronic brake assist, cup holder divider, and the divider + mag light holder for behind the rear seat. Actually, I have an extra bed bolt (hook rope assembly?). Also, I ordered a Pro Clip Dash Mount, it snaps on (no screws) to the dash near the environmental controls to hold a cell phone, I-pod, or Sat Radio, it is actually still in its package. You can use it to mount your Scan Gauge II.
http://www.proclipusa.com/?sectionpa...p_leftorright=
You pay for shipping its all yours.
__________________
Traded in: 2005 Tacoma DC PreRunner SJ Package Silver Streak Mica
Traded in: 2007 Camry LE Silver
Rivalred is offline
Old 03-22-2007, 07:06 AM   #10 (permalink)
Quote:
www.weathertech.com
Whatever he passes on let me know, I would definitely be interested in some of it.
I haven't owned weather-tech but if i had it to do over again i would have spent the extra on those over the Toyota all-weather ones.
justinh is offline
Old 03-22-2007, 07:33 AM   #11 (permalink)
Sporticus's Avatar
Here is the coolest scanguage II trick I have seen yet.
Scanguage II placement
__________________
2005 Tacoma
Sporticus is offline
Old 03-22-2007, 01:40 PM   #12 (permalink)
It's neat but I will keep my compass and outside temp gauge.
justinh is offline
Old 03-22-2007, 07:02 PM   #13 (permalink)
AH64ID's Avatar
x2
__________________
-John
AH64ID is offline
Old 03-23-2007, 10:18 AM   #14 (permalink)
Jacket's Avatar
With the 1" spacers, don't you think you'd be fine with a 75 series, like 265/75/16, with chains? In some cases, the 75 series tire is actually cheaper than the 70 series for the same model. You'd get a bit more height without really sacrificing much for suspension performance. Plus - it would probably fill that wheel well a bit better. Just an opinion - replacing those Rugged Trails with just about anything will improve performance immensely....
Congrats on finally getting your truck. She's a beaut!
__________________
06 Tacoma TRD OR 4x4 V6, TRAC, DAC, OME, ARB, Warn, Demello...
Jacket is offline
Old 03-23-2007, 10:55 AM   #15 (permalink)
Sporticus's Avatar
You guys with your fancy TRD packages. See, I have nothing up there to hinder such a mod on my SR5, if I had a scanguage.
__________________
2005 Tacoma
Old 03-23-2007, 02:05 PM   #16 (permalink)
Jacket's Avatar
Hey, you. Don't I know you? LOL.
Long live Tubby in Kentucky!!
(sorry John...back on track now)
__________________
Jacket is offline
Old 03-23-2007, 08:17 PM   #17 (permalink)
AH64ID's Avatar
Spacers offer zero additional clearance for tires. I have to play with the suspension compressed to determine what I can run.
__________________
-John
AH64ID is offline
Old 03-23-2007, 09:42 PM   #18 (permalink)
Jacket's Avatar
I understand that - I thought we were talking about wheel spacers & chains? oh well - I'm sure you'll figure it out....
__________________
Jacket is offline
Old 03-24-2007, 06:31 AM   #19 (permalink)
AH64ID's Avatar
Gotcha (brain fart)... yeah it will all depend. 265/70 and 265/75 are the same width. Its the clearance to the upper a-arm the 1" wheel spacer will allow for... I will be spending plenty of time flexing and measuring this summer before ordering tires.
__________________
-John
AH64ID is offline
Old 03-26-2007, 10:34 PM   #20 (permalink)
AH64ID's Avatar
After the first road road trip we got 19.2 mpg (well 19.198 by the math and 19.2 on the scangauge). on the first leg and 19.8 on the second leg. What a great truck.... the 5 speed auto is awesome.. when it down shifts on grades it wont upshift until the apex of the hill, even if you relax the throttle. So many features I love...
__________________
-John
AH64ID is offline
Old 04-07-2007, 07:31 AM   #21 (permalink)
hey john, so for the coil spacers up front, u got the 3/4 of a inch, right? why do they sell the two inch if it makes it higher up front?
__________________
Ed
Old 04-07-2007, 08:04 AM   #22 (permalink)
AH64ID's Avatar
Quote:
Dunno, but yeah I lifted mine 1.75" and its DEAD level.... 2" would have been too much, but 1.5" may have been better, so with a light load its still level... I think I am going to add 1/4 - 1/2" blocks (whatever I can get out of the OEM u-bolts) and air bags.... Thou the truck looks sharp right now.
The spring spacer is 1", the top plate is 3/4"
__________________
-John
AH64ID is offline
Old 04-07-2007, 03:07 PM   #23 (permalink)
im gonna put a randy ellis light bar up front. do you think i should go with 1.5 or 1.75 or 2? I ask because i still want it to be level with the light bar. thanks for your help.
__________________
Ed
Old 04-07-2007, 04:26 PM   #24 (permalink)
AH64ID's Avatar
Mine is level with the 1.75", but for my appearnce reasons I could go a hair lower, but I will just bring the back up a hair.... How heavy is the light bar? Really the OEM springs are probally 500+ in/lbs... so a 40lbs bar wont do a thing.. lift it what you want...
__________________
-John
AH64ID is offline
Old 04-08-2007, 12:42 PM   #25 (permalink)
mt_goat's Avatar
Here's what a local dealer had on the lot last year, might give you some ideas:
Sliders and bumpers are from Allpro.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
AH64ID's Truck AH64ID Trucks, 3rd gen-'89 to '95 2 08-14-2008 01:27 PM
Lift Needed on my 07 Taco sbikes 03+ 4Runner/GX470, & 05+ Tacomas 10 05-19-2007 09:14 PM
Featured Rig for the week of 05-06-07 (04 Rocko Taco) Corey Featured Rigs 0 04-17-2007 03:20 PM
New 07 Taco TRD!! Mickdady 03+ 4Runner/GX470, & 05+ Tacomas 4 01-14-2007 10:32 PM
Nice Lifted 07 Taco on eBay but youll pay 4 it! 4Runner4Christ 03+ 4Runner/GX470, & 05+ Tacomas 15 11-03-2006 11:31 AM
2009 InternetBrands, Inc.
