| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
91 Gas Necessary
#2 (permalink) |
You do not need 91... I noticed no difference from 87 octane to 94 I even used when I have my Tacoma. Just goos ole 87 octane and you will be fine.
__________________
Traded in: 2005 Tacoma DC PreRunner SJ Package Silver Streak Mica Traded in: 2007 Camry LE Silver |
#3 (permalink) |
Good to hear, so i guess you haven't noticed any pinging sounds coming from your engine. I heard putting lower octane (then recomended) can take its toll on the engine over time since it takes less compression to combust.
#4 (permalink) |
I use w/e I feel like at that moment... Usually 87. I notice NO performance gain from 87 or 94 octane.
__________________
'02 4Runner - '06 XRunner Breakdancing www.BadgeYourRide.com Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/ Highest Xmax 6.5" subwoofer made Total Posts: 32,218 (75.35 posts per day) [/center] [/color] Still A Neon |
#5 (permalink) | |
Quote:
__________________
2003 4Runner V6 Sport / X-REAS Gone / Front Hoe's / Rear Deaver's + Hoes Demello Hybrid Sliders / Demello Bumper / 33" TrXus Mt's / Mojave Teflons / TC UCA's Source CO2 / Lightforce 240's / M8000 + Rockstomper Synth / Tubing Works Rear Cage! Profile and Pics |
#6 (permalink) |
94 octane? I'd never use anything higher than 91, unless you want waste money.
__________________
Who Dares Wins |
#7 (permalink) |
on the '05 and newer tacoma, we have a knock sensor and vvt. you can run almost any grade octane. but, low octane will cause the sensors to retard timing (reducing a little power efficiency, and mpg). i have an auto trans, and it was noticable with the cruise control on.... trans would down shift, sometimes multiple gears when not necessary. i started using the mid grade octane, and on the same roads the down shifting has greatly reduced. you may not notice the engine timing being retarded when driving a manual trans...
__________________
'05 prerunner access trd sport pkg 2 |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Dust off your gas guzzling Ford Broncos---gas prices forecasted to drop even further | Bob_98SR5 | Off Topic Talk | 14 | 09-06-2006 08:45 PM |
| Strong smell of gas...not exhaust...GAS! | vegascoug | 86-95 Trucks & 4Runners | 21 | 05-01-2006 07:45 PM |
| Will 15" wheels & tires 31 x 10.50 R15 from a 91 4runner fit on a 91 Land Cruiser? | weezy | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 06-18-2005 07:45 PM |
| bad gas mileage 91 4 runner | newjerseyredneck | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-08-2004 04:13 PM |
| 87, 89, or 91? which gas do you use? | Dragonbud | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 10-12-2002 07:28 PM |
