2005 4runner cranks but won’t start intermittently
160K miles - Engine turns over, but won’t start with no check engine light. As a precaution, I checked the simple things: battery terminal ends for corrosion, battery (checked good on CCA and load test), shouldn’t be the starter but I also checked and temporarily replaced the starter relay, checked fuel pump relay, verified engine had spark, changed spark plugs 1-2 months ago with no issue until now, changed/checked air filter.
After checking all of this, I simply removed/reinstalled the gas cap and it fired right up.
Anyone else have similar experience or could offer any guidance? I’m thinking it is the fuel pump.
