2.7 4 Runner flatspot
Old 03-19-2015, 12:26 PM
silversurfrunner's Avatar
Hi all.
My 1998 4Runner (Hilux Surf) is driving me to distraction. I have just replaced the cylinder head and since I put it back together it starts and idles beautifully but often when you press the throttle to accelerate she seems to bog down but if you put it to the board then she takes off like a scalded cat. All 16 valves are new, all genuine Toyota gaskets and parts were used and it has cost a small fortune but it is really annoying. The CEL light is not on and I don't think that timing is an issue because she runs perfectly apart from this horrible flat spot. I have owned her for the last 15 years and this is the first problem she has had other than routine servicing. The plugs leads and dizzy cap and rotor arm are all new.
Does anyone have any ideas ?
Old 06-01-2015, 07:35 PM
snowboardwcu's Avatar
did you ever figure this out? curious of the cause, thanks.
Old 06-02-2015, 09:57 AM
Hi there. I have still got the problems. She has settled down a little but she is still way off being right. I am going to buy new O2 sensors and various other sensors etc to try and resolve the problem.
Old 10-19-2015, 06:05 PM
i knew i asked this somewhere and took until right now to find it.
my V8 at 145k does something a little similar. i notice that if i'm not rough on it, making it kick down gears, she likes it better. its forced me to drive more conservatively, which is probably a good thing. but no idea what it is.
Old 10-19-2015, 11:00 PM
Hi there.
The short answer is no. I am sure the knock sensor is faulty, or possibly the wiring. I really need to sort her out now. It is driving me mad !!!
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2.7 4 Runner flatspot
