'05+ Tacoma TSB's
'05+ Tacoma TSB's
It might be a little late for some of you, but I have found a few that I'm starting to experience.
99% of these are covered either under the Emissions Warranty (96mo/80k) or the Comprehensive Warranty (36mo/36k).
A TSB (Technical Service Bulletin) is not a recall.
AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
BO003-05 MAR 05 Body - Overfender Refinishing Process
BO004-05 APR 05 Body - Water Leaks Onto Front Floor
BO018-07 NOV 07 Body - Bent Rear Tailgate
BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
NV004-06 MAY 06 Interior - Front Seat Squeak Noise
NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
NV007-07 JUL 07 Body - Dech Side Panel Rattle
PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
PG004-06 NOV 06 General - TPS Diagnostic Tips
SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
SU002-05 NOV 05 Suspension - Rear Suspension Noise
SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
T-SB-0132-08 JUL 08 Drivetrain - Driveline Vibration Between 15 - 25 MPH
T-SB-0305-08 SEP 08 Suspension - Rear Spring Harsh Ride
I have all the .pdf files for these, just don't have time to host them all up right now.
You can Search here or Google the TSB number for more information.
I'll post back up when I get the files hosted somewhere.
Fink
Fink
the bent rear tailgate... was it like that from factory or do you mean that it's weak and you've bent it? Mine is like paper and has bent in the center several times. I can't even sit on it and i'm only 215lbs.
If you want the .pdf file for the TSB, PM me your email and I'll send it to you.
Fink
is the tailgate TSB still in effect for a 2005 taco? I don't usually run the tailgate on mine but I'd like to have it reinforced because they are pretty much useless otherwise.
LCE_Performance
10-01-2015 01:03 PM
bryan34w
12
09-30-2015 02:50 PM
charlie_fong
09-27-2015 10:06 PM
