03 T4R - New battery, Dies at stops, Lights get brighter when revved... help!
Old 08-17-2014, 11:05 AM
CFM
CFM's Avatar
So I decided to clear and paint the headlights on our V6 03 T4R yesterday, had the front bumper off obviously and the bulbs were laying freely. I had my fiance' pull it forward a little bit (it started to rain) and she forgot to turn the lights off, luckily I noticed within a few minutes and saw smoke. The high beam bulb burned about a inch in diameter hole in the battery. I figured well crap, I need a new battery obviously and we should be fine. Went and bought another new battery, installed it... and the car was idling low (around 500 RPM's) and when it was idling the headlights were dim, when I'd rev the vehicle the lights would get brighter. When I am driving, it drives fine until I come to a stop. Then it dies. I figured it was a faulty battery, nope... I'm thinking voltage regulator or alternator...
What could have happened? The vehicle ran perfect before this happened. I hope I was detailed enough to get some help! Thanks T4R!
-Coleton
Old 08-20-2014, 08:01 PM
CFM
CFM's Avatar
I have a brand new battery and alternator.... it's still running the same... Very low idle, to the point where it is basically dying or does die. When I rev the truck the lights get brighter. All the same symptoms.... I'm at a loss here.... Anyone?
Old 08-20-2014, 10:43 PM
totally a bro
Staff
vital22re's Avatar
some newer vehicles take some driving time after a full power loss for the ecu to relearn driving patterns etc. Had this happen on an Is300 after battery replacement. A couple days later it was fine. Not saying its the same thing, but possible. You may want to go through and check your fuses just in case. Otherwise nothing obvious jumps out at me.
Charecter1
11-06-2023 10:08 AM
06-01-2021 01:51 PM
v_man
07-23-2015 04:01 PM
Johntom240
7
07-13-2015 12:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 03 T4R - New battery, Dies at stops, Lights get brighter when revved... help!
