ZUK Mod Trail Experience?
Old 08-19-2013, 08:05 PM
JookUpVandetti's Avatar
First off thanks for the help and the tons of info on this forum, its really helped me out.
Very interested in doing the ZUK MOD no cut, I think even I can do it. I'm also plan on adding 1.5" ball joint spacers. Recently Got a Budbuilt transfer case crossmember. Main goal is to get a bit more clearance as I've hung up a few times on the TC crossmember.
Question is how does the ZUK MOD do on trails, actually wheeling? Will I need new shocks?
Old 08-19-2013, 08:09 PM
INFINITY's Avatar
using the springs on the bumpstops it does not articulate that well.
if you zuke mod off of the center of the rear diff it articulates very good. you just have to run a crossmember from frame to frame to mount the upper perch of the coil.
we ran a dual set of tj front coils off the rear diff due to the weight used and the tg 4" springs are super soft.
Old 08-19-2013, 08:40 PM
'85 Yota's Avatar
The zuk mod worked decent. I didnt have as much up travel as stock.
Old 08-19-2013, 08:46 PM
Hmmm thanks for te replies, don't think it will work for me.
punks_is_4x4
08-21-2015 01:35 PM
ATVTRAILRIDER
08-19-2015 06:44 PM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: ZUK Mod Trail Experience?
