Zuk Mod Questions
Old 03-04-2015, 04:33 PM
BLACKrussian1's Avatar
Zuk Mod Questions
Hello all!
I have a 86 Sr5 4runner that is sagging in the rear a bit. I am interested in doing a Zuk mod to lift it back up and smooth out the ride. I know most mods use the Jeep coil springs because they are a perfect fit around the bump stops. The problem is I've been looking for weeks on my local craigslist and walking the flea markets searching for some jeep springs and come up empty. Are there any other make/model springs that could work for this mod?
thanks!!
Old 03-04-2015, 06:49 PM
DJ99's Avatar
Here's a pair for $42:
http://www.ebay.com/itm/Pair-of-1997-01-Jeep-Cherokee-XJ-4-0L-front-coil-springs-NICE-/131340755051?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e9484e06b&vxp=mtr
I saw more at $50 for a pair.
Old 03-04-2015, 07:53 PM
Thanks!! ill keep those in mind. Im headed out to the salvage yard tomorrow to see if I can find some. If I strike out those ebay springs might be just what I need. If anyone else has any ideas on other model springs plz let me know.
Thanks!!
Old 03-04-2015, 08:12 PM
95blackToy's Avatar
I used the smaller ones.
14 inchers
http://cgi.ebay.com/ebaymotors/NEW-R...mZ290014125492
Old 03-04-2015, 08:30 PM
14 inchers
did you have to modify the bump stops or did they fit over them?
Old 03-05-2015, 03:49 AM
95blackToy's Avatar
Fit right over my bump stops. Rides better, tows better. And will NEVER bottom out again.
Old 03-05-2015, 06:39 AM
thefishguy77's Avatar
With the second link provided you can also choose what poundage you want with the springs. 100, 125. Ect. More easily customized to you. I think you can also choose between an 11" and the 14" in the link. Depending on your needs.
Zuks site gearinstalls.com has some great examples of the springs used and for what applications the drivers needed them for.
If your runner is usually empty the the softer springs will probably be best, but if your rolling around with a back full of tools and fuel cans on the rear bumper then the stiffer ones would probably work better. Personally if I do it I will go with the stiffer ones because I am wanting to fav up a plate rear bumper with tire carrier and the ability to hold 2 NATO fuel cans back there. Not to mention the wife, kid, and 2 dogs as well.
Old 03-05-2015, 07:09 AM
papawhellie's Avatar
I need to do this as well. Junkyard gets about 14.oo each for the coils. Seems like they would be a pain to pull having to drag a jack back there in a wheelbarrow. The JC Whitney springs for 42 bucks seems pretty good. Not sure I want to pull springs for 20 bucks worth of my time. What is the consensus. I would like to know what vehicles to pull as well. What jeep? My closest yard has these. So with the sag in my avatar I need a 8 to 12 inch tall spring with a 2 1/2 inside diameter?
Make Model Year Date On Yard Row
JEEP CHEROKEE 2001 12/10/2014 91
JEEP CHEROKEE 2001 03/04/2015 90
JEEP CHEROKEE 1999 12/06/2014 91
JEEP CHEROKEE 1995 02/16/2015 88
JEEP CHEROKEE 1994 01/01/2015 81
JEEP CHEROKEE 1994 12/10/2014 91
JEEP CHEROKEE 1993 12/31/2014 81
JEEP GRAND CHEROKEE 2004 01/12/2015 83
JEEP GRAND CHEROKEE 2004 02/04/2015 86
JEEP GRAND CHEROKEE 2003 01/07/2015 83
JEEP GRAND CHEROKEE 2003 02/16/2015 88
JEEP GRAND CHEROKEE 2002 02/13/2015 87
JEEP GRAND CHEROKEE 2002 02/13/2015 88
JEEP GRAND CHEROKEE 2002 03/02/2015 89
JEEP GRAND CHEROKEE 2002 02/02/2015 86
JEEP GRAND CHEROKEE 2002 12/15/2014 92
JEEP GRAND CHEROKEE 2001 12/31/2014 81
JEEP GRAND CHEROKEE 2001 12/12/2014 91
JEEP GRAND CHEROKEE 2000 01/30/2015 86
JEEP GRAND CHEROKEE 2000 01/07/2015 83
JEEP GRAND CHEROKEE 2000 12/10/2014 91
JEEP GRAND CHEROKEE 2000 03/02/2015 89
JEEP GRAND CHEROKEE 1999 04/29/2011 89
JEEP GRAND CHEROKEE 1998 12/18/2014 93
JEEP GRAND CHEROKEE 1997 12/31/2014 81
JEEP GRAND CHEROKEE 1997 01/02/2015 82
JEEP GRAND CHEROKEE 1997 01/06/2015 82
JEEP GRAND CHEROKEE 1996 12/18/2014 92
JEEP GRAND CHEROKEE 1996 12/29/2014 80
JEEP GRAND CHEROKEE 1996 01/12/2015 83
JEEP GRAND CHEROKEE 1996 02/02/2015 86
JEEP GRAND CHEROKEE 1996 01/19/2015 84
JEEP GRAND CHEROKEE 1996 02/10/2015 87
JEEP GRAND CHEROKEE 1995 01/16/2015 84
JEEP GRAND CHEROKEE 1994 01/16/2015 84
JEEP GRAND CHEROKEE 1994 01/26/2015 85
JEEP GRAND CHEROKEE 1993 01/16/2015 84
JEEP GRAND CHEROKEE 1993 12/31/2014 81
JEEP GRAND CHEROKEE 1993 02/18/2015 88
JEEP GRAND CHEROKEE SRT-8 1995 12/26/2014 93
JEEP J-10 PICKUP
Old 03-05-2015, 01:24 PM
Yea Salvage yard had one runner there and it was picked clean. No Wranglers, they did have some Cherokee's there and the coils were about 14 bucks each but you are right about having to yank them off and all that. I ordered the Cherokee springs for 42 bucks that way I don't feel so bad if I have to do some cutting. the springs come in on the 13th so ill get to it that weekend hopefully and let you guys know how it went.
Old 03-06-2015, 12:33 AM
RAD4Runner's Avatar
14 inchers
IF you value your time more than a few bucks, this spring is the way to go.
The "2.5625" Inside diameter springs will fit perfectly around the bottom bump-stop but will NOT fit around the top bump-stop of the 1986 4Runner. It will require cutting the upper bump-stop in order to make it fit.
The 14-inch version will add a rake, requiring you to use BJ spacers in front or cranking torsion bar to make height level.
However, the 12-inch one will bring back stock height, without need to lift the front.
I'm very happy with mine (12-inch, 125 lb/inch rate) here.
Old 03-06-2015, 04:15 PM
Nervo19's Avatar
Mine are 2000 Jeep Wrangler front coils. They are 16" so have be to cut down to use. Now I'd probably go for 95BlackToy's eBay springs for simplicity's sake.
Old 03-06-2015, 07:16 PM
RAD4Runner's Avatar
Another option... I think springs for 3rd-gen 4Runner have large-diameter top that will fit around the upper bump-stop and small diameter bottom that will fit around lower bump-stop. This allows no-cut, no-weld Zuk.
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-11-2015 07:21 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Zuk Mod Questions
