ZUK mod... gonna try it!
Old 04-02-2012, 05:36 AM
87-4runner's Avatar
Ordered the 12" 120# springs for to do the ZUK modification on our 87 4runner.
I am going to take pics of the before, during and after installs and post them.
Can't wait to try this!!!!!!!!!!
THIS would be BEFORE..
THIS would be AFTER..
Storage and Stereo Components Amps Crossovers etc....you can see the hinge....the little storage is the stereo stuff.....and its vented.
Old 04-02-2012, 06:52 AM
Junkers88's Avatar
It's a great mod. Nice looking rig you have there too!!
Old 04-02-2012, 09:37 AM
ZUK
ZUK's Avatar
Ditto....your rig definitely qualifies for the coils
Old 04-04-2012, 08:31 PM
jrock08's Avatar
Nice looking rig! Mine looks very similiar as far as the sag goes. Hopefully I'll be doing my zuk mod before much longer.
Old 04-05-2012, 02:32 AM
92 TOY's Avatar
post up some pics and measurements if you could. MIGHT be doing this later today if everything goes right. (start near the end of page 68..... https://www.yotatech.com/forums/f199...0/index69.html )
Old 04-05-2012, 05:04 AM
worshipmentor's Avatar
Been there......done that.....has to be the BEST MONEY EVER SPENT on my yota! You'll be so happy you'd kiss Zuk if you could find him............... but he does a GREAT JOB of staying hid..
Old 04-05-2012, 03:34 PM
92 TOY's Avatar
our ZUK mod is done... check out Joe's build thread
Old 04-05-2012, 09:28 PM
ToyoTech559's Avatar
runner looks great and the zuk mod is awesome. i got a nice lift out of it and it still flexes like before
Old 04-05-2012, 11:10 PM
89StormTrooper's Avatar
Nice, I'll check back for the results as I'm going to do this to my runner soon also. The rubber on mine is about 2 1/2 inches away from the bumpstops and rides rough as hell.
Are you going the welded or non-welded route?
Old 04-06-2012, 03:04 AM
92 TOY's Avatar
here ya go
https://www.yotatech.com/forums/f116...r-turn-251897/
Old 04-06-2012, 05:52 AM
87-4runner's Avatar
Getting things ready .........
Torch is outside and ready to light.....:wabbit2:
Won't be long now.....
Old 04-06-2012, 05:58 AM
conquistador's Avatar
Good looking 4runner. Where in Oklahoma are you located? I'm getting ready to do this mod in the next couple of weeks.
Old 04-06-2012, 05:59 AM
87-4runner's Avatar
Oh yeah.......this is functional ram air I made..........and the push bar on the front with mini-winch is made of 2 3/8s upset tubing.....bolted to frame.
Old 04-06-2012, 06:02 AM
87-4runner's Avatar
Old 04-06-2012, 06:03 AM
thedrewski86's Avatar
If I'm reading 92TOY's thread correctly, he didn't even have to torch anything. Am I right?
I've been halfway looking at this mod myself for my 94 p/u. I don't have a sag issue but I've heard this helps with overall ride. My truck seems like it will just about buck itself off the road when I hit some bumps, would this help?
Old 04-06-2012, 06:04 AM
87-4runner's Avatar
Thank you......over by Enid.
Old 04-06-2012, 06:05 AM
92 TOY's Avatar
right. because we got the 5''OD springs to fit over the bumpstops. no torching at all.
if he is doing the cut method, I understand some torching may be necessary to spread the upper bumpstops.
Old 04-06-2012, 06:07 AM
87-4runner's Avatar
Correct.......just depends on how you want to do your ZUK mod, lots of ways to skin a cat. And yes I thing it will help your ride....sounds like you need shocks also if its bouncing.....
Old 04-06-2012, 06:17 AM
87-4runner's Avatar
This is the original 22RE in the truck but it has been modified......
Custom valve grind to match custom bump stick...LCE header... cold air induction mod to air box.... K&N air filter....Synthetic Mobil 1 fluids everywhere
Also did some adjustments to the Mass Air Flow Controller...18" glass pack in front of a 60 muffler.....added the glass pack for a little back pressure and to kill the "frag"..... sounds nice and deep and growls at WOT. New Aluminum Radiator, Put in electric fan to gain more HP that the mechanical fan robs from the little 22re. After all the mods I can cruise 65-70 and not have to down shift to 4th gear to pull hills....YEAH!
Probably added a total of 40-50 horses........Still not a dragster but runs real sweet.
Old 04-06-2012, 06:21 AM
87-4runner's Avatar
Exactly 92.....I got the 2 1/2" x 12" x #120 springs that will go over the rubber snubber and inside the legs of the bump stop.
Quick Reply: ZUK mod... gonna try it!
