wwhat type of lift is this????
Old 03-17-2010, 03:55 PM
8yota6's Avatar
hey i am pretty new to 4x4's in was just wondering if anyone knows what kind of lift this is?
Old 03-17-2010, 04:01 PM
BackGateYota92's Avatar
Wow that looks kinda odd. its like its some kind of weird lift block. lol i would like to know what that is also.
SpecialScottie's Avatar
Those look like stock springs with an add a leaf. And them some kind of home made block on the bottom
It looks like its extended out to reduce axle wrap
Old 03-17-2010, 04:02 PM
2DoorRunner's Avatar
wth?
I have never seen anything like that before. Looks sketchy to me.
Old 03-17-2010, 04:04 PM
i cant really see how that would reduce axle wrap though?
Old 03-17-2010, 04:06 PM
Yeah it looks like it would limit flex alot.
Maybe some sort of bump stop?
Old 03-17-2010, 04:08 PM
8yota6's Avatar
thought it was weird also. i looked at tons of lift kits and knone of them lokked like what i got. maybe i'll look into a real lift kit. any recommendations?
Old 03-17-2010, 04:12 PM
well by looking at your truck i assume you have a 4" drop bracket lift and 3" body lift right??? so i guess any 4" leaf pack would work. your truck looks beast btw. i love the whole wide tire look. what size tire and rims you running?
Old 03-17-2010, 04:15 PM
8yota6's Avatar
33x15.50x15/ thx
Old 03-17-2010, 04:18 PM
your rig looks real mean for sure. lol as far as lift though you might be able to put some chevy springs and a shackle or add a leaf. i think that should net you around 4 inches of lift give or take
Old 03-17-2010, 04:23 PM
akaphilly's Avatar
looks like you have an add a leaf and that block. i would ditch that and get some f150 springs or trail gear.
oh ya... nice bald tires !
Old 03-17-2010, 04:31 PM
8yota6's Avatar
yea in the process of looking for new tires
Old 03-17-2010, 04:51 PM
you gonna keep the fat stance??? haha
Old 03-17-2010, 04:55 PM
b4wheeler's Avatar
That is called a "traction lift".
There were sold many, many years ago....
Funny thing is, they are on backwards....
They are designed to be traction bars and lift block in the same unit......
http://www.gotojeepaccessories.com/w...ction_lift.asp
TRACTION LIFT
Acts as a lifting device and as a traction bar. Warrior traction lift is a fully adjustable traction bar to help preload all your traction needs. The traction lift replaces your 2 1/2" lift block or can be used as a 2 1/2" lift for added ride clearance. The system mounts between your leaf spring pack and your differential housing, with the main bar pointed forward, on the rear end housing of your vehicle. The vertical "U-shaped" bars extend above the leaf spring where two cross pins are installed. The traction lift system is not designed to be used in the front of the vehicle. If you are not replacing lift blocks when you install your traction lift, you will need longer u-bolts
Old 03-17-2010, 04:57 PM
Dang thats weird. i guess its not useless after all??? lol
09-04-2015 09:27 AM
mistershmi
08-31-2015 03:44 PM
Ernie217
08-14-2015 05:25 AM
Poppie51
08-02-2015 11:29 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: wwhat type of lift is this????
