Wrist pin? - YotaTech Forums
Go Back   >
Wrist pin?
LinkBack Thread Tools Search this Thread
Old 01-08-2013, 07:59 PM   #1
Wrist pin?
The search engine here wont work with my phone and its the only internet I have, I did a google search and came up with a couple results but they were from a few years ago and werent similar to my situation. So here goes, im gettin an 88 pickup 22re 300k plus miles on truck, supposedly the top end was rebuilt not long ago, i know the guy im gettin it from and he is reputable and honest. He told me his toyota man who did the other work listened to it and said its a bad wrist pin. And he could fix it for 500 bucks. When you first start it theres a slight knock/rattle not bad only does it for a short time after starting, also does it when youre decelerating(let off the gas) its even more faint then, almost inaudible or non existant. So my questions are, does this sound like a wrist pin problem? Is 500 about right to fix it? What all is involved in fixing it? Other than that everything works except the dome light and cig lighter, the door buzzer doesnt work either so,maybe theyre on the same circuit and it has been disabled. And the front tires are cupping. No rusy, no dents. Any help or advice is appreciated. Thanks guys.
8088 is offline   Reply With Quote
Old 01-09-2013, 01:18 AM   #2
TNRabbit's Avatar
Sometimes the timing chain rattle from broken chain guides can sound like a wrist pin issue....
TNRabbit is offline   Reply With Quote
Old 01-09-2013, 02:16 AM   #3
Thanks man, ill check that. He said the timing chain and top end have been rebuilt tho. Not sure.
94 22re sr5 4Runner clutch and shifting issue punks_is_4x4 86-95 Trucks & 4Runners 1 02-26-2016 05:29 PM
3VZE Running Rich, slight high idle. LOSING MY MIND trying to troubleshoot. Longbed 90 86-95 Trucks & 4Runners 27 10-19-2015 12:05 PM
Can't find pinouts for this ECU Gone Fission 86-95 Trucks & 4Runners 9 09-22-2015 05:51 AM
CODE 52, Knock sensor gurus please read. some drunk guy 86-95 Trucks & 4Runners 5 09-20-2015 09:22 PM
94 3.0l Cold Idle???? moparbay 86-95 Trucks & 4Runners 1 09-03-2015 01:48 PM
Tags
2002, diesel, pin, runner, sounds, timing, toyota, wrist, wristpin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
