Wrapping wires with foil for heat protecting?
So the group of wires on top of my x member is getting a little hot and kinda burnt from the exhaust pipe. I dont want to go out and buy $20 worth of heat shielding when i just need a 4'' piece.
Should i use some foil to protect the wires from melting? The wires are about 3'' away from the pipe but they are just starting to get cooked.
^lol
well I've never seen tin foil used before for that, lol
personally, I'd use some stuff made for it; just cut some off any junk yard car or something instead of paying $20 for a full roll...
a little exhaust wrap around the pipe is an option.... but I don't think I'd use foil. A smooth surface is a much better reflector... or grab a piece of fiberglass insulation from somewhere.
I really like the thermo-tec line.
I had issues with burning spark plug wires, alternator wire and even starter after I got my thorley headers.
I wrapped everything in thermo-tec and then clamped the tape over each line using a metal clamp. It looks professional and offers excellent thermal protection from radiant heat (they claim it protects from over 90% of heat up to 2000 degrees). Again, this isn't header wrap (that's NOT a good idea) but this is for wrapping anything that will get too hot. You can find this tape cheap if you look around. Good luck
[IMG]
Click for full size [/IMG]
[IMG]
What part of the car would i get it off of?
Pretty much. Just cruise the junkyard and look for heat insulation in good shape. Most times everything is already taken apart so you can just slide off the insulation
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
