Wow!!! Lucas Oil an Sea Foam Wow!!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-18-2008, 04:41 PM   #1 (permalink)
I read and read on this forum about these two products..and finally put yall to the test...lol
Went to AutoZone today an told the man to hit me with Lucas and Sea Foam...added them in the parking lot...a couple of hours of driving later...it seems for real like I dropped almost 100,000 miles off of my truck...
How long does this feeling last...lol. How often can I SeaFoam my rig and how much is too much Lucas Oil...I wish I could just change my oil and put nothing but that shizz in there, lol.
__________________
2000 4Runner Limited
White/Silver
Leather / Woodgrain
Power Everything / Sunroof
BrunswickYota is offline
Old 01-18-2008, 04:47 PM   #2 (permalink)
ovrrdrive's Avatar
Well, Lucas lasts for about 10,000 miles before you have to rebuild the motor from using it.
Happened to me twice... Be careful what you add to the engine.
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 01-18-2008, 05:03 PM   #3 (permalink)
slacker's Avatar
I love the LUCAS oil treatment ..
trick is to add it AFTER you have oil pressure .. if you add it to soon it will take a while to get oil pressure , and could take out main bearings ..
I have used it on my rebuilt engine .. 1/2 container , per 2nd oil change ...
40K on it now .. and still runs like a champ , large oil pressure , and fires right up , everytime ..
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 01-18-2008, 08:44 PM   #4 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
yeah but pressure vs flow i have low oil pressure and very high flow!!! rebiult her and i can sit there and bounce her off the rev untill the fuel tank is gone and still nothing well maybe not but yeah high pressure = low flow high flow= low pressure and im getting everything right away -5 outside first key start and still no ticking baby
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 01-18-2008, 10:13 PM   #5 (permalink)
Red3.slow's Avatar
Send a message via AIM to Red3.slow
I usually do the seafoam treatment about once every two to three months, works like a champ.
Lucas I use a little every oil change.
__________________
-Miles
-Firefighter/EMT
T.E.A
Taxed Enough Already
Red3.slow is offline
Old 01-18-2008, 10:28 PM   #6 (permalink)
infiltrator's Avatar
Send a message via AIM to infiltrator
i started two threads each about this and have learned so much.
i did seafoam through the brake booster, and at once heard a sexy roar from my engine.
when i did it in the brake booster, a ton of smoke emerged right before i turned off the truck. when i started it up, puffs, but nothing major. so i guess i was pretty clean.
as far a lucas' oil stabalizer, i love the stuff. it stopped ALL my oil leaks (maybe a drip here and there) but havent had to add any oil AT ALL since i used it. on the bottle it says to use it instead of a 5th quart of oil.
both of these i think helped my truck so much.
and my napa gold filter :]
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled.
infiltrator is offline
Old 01-19-2008, 11:29 AM   #7 (permalink)
89RUNNERFFD's Avatar
I have been using the Lucas oil as my 5th quart also. Truck runs like a champ. Will try it without next change. Thanks for the heads up on Lucas.
89RUNNERFFD is offline
Old 01-19-2008, 12:06 PM   #8 (permalink)
In my younger days, STP was the rage. It was great for motor assembly, worn engines suffering from low oil pressure and burning oil. Any thing else it was detrimental to a perfectly good engine. Why, its viscosity and reluctance to pour at room temperature. Simply, it starves bearings on a cold engine start. That is also were most engines slowly die, cold engine startup. This is also why synthetic oil is far superior to dyno oil in that it flows like water when cold.
So, STP, Motor Honey, Lucas and the likes are great for problem engines and new motor rebuilds to coat moving parts.
By the way, diesel fuel will accomplish the same results as Sea Foam. Save that Seafoam can and put some diesel fuel in it for the next treatment.
My $0.02
SEAIRESCUE is offline
Old 03-10-2008, 01:32 PM   #9 (permalink)
Matt16's Avatar
Diesel will just smoke won't it? Seafoam's a powerful solvent.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 03-10-2008, 02:25 PM   #10 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
How did you do the seafoam treatment?
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 03-10-2008, 02:40 PM   #11 (permalink)
olharleyman's Avatar
I used a gallon of LUCAS from the day my peterbilt was new to 500,000 miles on it and at 500,000 it is recamended to have the mains redone when the CATERPILER guys pulled the oil pan they said the bearings were as good as new. Since then I have used it in both of my HARLEYS transmissions and motors my 4runnner every 3rd oil change added it to the thirds transfer and transmission and now have 230,xxx miles and counting with zero issues.
__________________
1990 4 runner 5 Speed
Pro Comp Stage II 4" Lift 6" coils rear
Aussie Locker front
5.29's Front And Rear
35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels
Super Charged 3.4 on the way
1993 SAS 4runner 22re 5 speed
4" front 5"rear
5.29's
35 x 12.5 BFG KM'S
Dick cepek DC 1's
88 stock 4runner
3.0 auto
for now
1955 Harley Davidson Springer
Stock 1955 Hardtail Frame
4 Speed
Kick Start Only
1998 Harley Custom Dresser
107 rwhp
139 ft.lbs.trq.
olharleyman is offline
Old 03-10-2008, 02:45 PM   #12 (permalink)
you guys are on crack. the only way i'd ever use lucas again is on an engine that was on its way out that I didn't have time to rebuild for a few thousand more miles. Theres no way that it lubricates properly seeing as its got the viscosity of cold honey.
MMA_Alex is offline
Old 03-10-2008, 02:48 PM   #13 (permalink)
keithguts's Avatar
I put a qt of LUCAS in every oil change I do (Every 3K Miles) I think this stuff is great. Never had a problem with it.
I also had a ford Exploer that the trans went out on me. It would not even go into gear. I was told to put Lucas trans aid in, and I did. The rig went into gear after warm up and me going to drive and back to park for a few mins. It then stayed in gear. I took it for a ride for about 1 mile, and the rig ran and shifted great for the next 2 years. When I sold the rig, it was still doing great. That was 3 years ago. I still see the rig around town, and the guy I sold it to told me that ,YEP, STILL RUNNING GREAT. TRUE STORY.
__________________
MY PICS
My Rig
My Rig
RangerMan
Enjoy
Old 03-10-2008, 05:33 PM   #14 (permalink)
If you use Seafoam to treat your engine, then change your spark plugs out after you're done admiring your smoke cloud. At least, take out a couple and inspect them after you're done to make sure you haven't fouled them out or caked them with deposits. Seafoam is notorious for crapping out plugs. So it's just a good idea to put new plugs in after. It's not that expensive, and easy as hell to do. I mean, it's good PM...so why not right?
__________________
-Dave
'88 Bob'd Longbed 4x4 22RE/ToyTec 2" Lift and All Pro 2" Shackles/33" ATs/ARB BullBar/Bestop Supertop/All Pro Rear Bumper & Custom Rear Tire Carrier
'92 FJ80/207,000 miles/Somewhat Stock
DCYota is offline
Old 03-10-2008, 06:19 PM   #15 (permalink)
ovrrdrive's Avatar
Quote:
This man speaks the truth...
I used it once and the motor blew a short time later. Several years later I used it again and again I had a motor crap out on me. I wouldn't touch it with a ten foot pole again...
__________________
'95 xcab - SOLD
Old 03-10-2008, 06:38 PM   #16 (permalink)
Well, to update from my last post. I didn't add lucas in my truck oil and I notice drips again. A lot.... ^#$#
__________________
Old 03-10-2008, 08:23 PM   #17 (permalink)
Quote:
Originally Posted by infiltrator View Post
Well, to update from my last post. I didn't add seafoam in my truck and I notice drips again. A lot.... ^#$#
quick get some cardboard! that honeygoo is impossible to get out of the driveway!
MMA_Alex is offline
Old 03-10-2008, 09:36 PM   #18 (permalink)
CoedNaked's Avatar
You guys should try Amsoil 10w30 Synthetic oil. I've pretty much run Mobil 1 10w30 synthetic up until now with the exception of one Amsoil change the change before last where I went back to Mobil one for one change. Well I just switched to Amsoil oil for good. Before doing the change I tried some of the Amsoil engine cleaner (I think it's called Engine restore or something like that) - you dump it into the crankcase and idle it for 15-20 minutes with the old oil then drain and add Amsoi oil. Man oh man what a difference. The truck now feels like I picked up at least a few HP and it runs much more "enthusiastically."
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids|
Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 323,600 KM's (202,250 miles) | Made in Japan - Vin starts with "J"| Fish on
CoedNaked is offline
Old 03-11-2008, 05:35 PM   #19 (permalink)
Send a message via AIM to shaeff
Agreed, and I'll never use Seafoam either. Research is key in these situations...
__________________
My heatercore replacement writeup with pics.
-'94 Toyota 4X4, 22re, 31X10.5 BFG M/T's, 5 speed, MC rear bumper. (Winter DD/ off road fun)
-'95 BMW M3, modded/suspension, sticky rubber, back road monster (Summer DD)
-86.5 Toyota Supra, too much to list. (Never-ending project)
shaeff is offline
Old 03-11-2008, 06:20 PM   #20 (permalink)
Brenjen's Avatar
I don't use oil thickeners like Lucas but I seafoam in the gasoline & oil about two or three times a year...it's just a solvent. It'll clean injectors & sludge; it's not some miracle juice that adds hp or magically restores cylinders....it is what it is. I think if someone were to run it in the gasoline in too strong of a concentration it might damage injector seals & that cloud of smoke people see when they add it to their vacuum lines is the seafoam burning lol
I suppose being used in the vacuum lines or if used in too strong of a concentration in the gas tank it could also cause some cat or o2 sensor issues....maybe that's why some people complain about that.
__________________
'95 4Runner 3.0 Automatic bone stock; it's becoming a project slowly but surely, one part at a time
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Brenjen is offline
Old 03-11-2008, 08:36 PM   #21 (permalink)
312necro213's Avatar
Well thats because some people think, "some is good then more must be better."
__________________
2001 4runner lift coming soon
1990 Sr5 4runner Project...
312necro213 is offline
Old 03-11-2008, 08:43 PM   #22 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
Quote:
with beer and other alcoholic beverages thats TRUE!
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 03-12-2008, 01:32 AM   #23 (permalink)
ovrrdrive's Avatar
Quote:
Also with women...
Well, as long as you're talking about multiples that is. More WOMAN isn't good at all!
__________________
'95 xcab - SOLD
Old 03-12-2008, 05:26 AM   #24 (permalink)
LOL too true!
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 03-12-2008, 09:49 AM   #25 (permalink)
Quote:
Originally Posted by ovrrdrive View Post
Also with women...
until they find out about each other...
MMA_Alex is offline
Tags
additive, better, davidson, dyno, foam, harley, horsepower, lucas, oil, sea, seafoam, stp, treatment, versus, withj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Do you Sea Foam and how? jacumja General Vehicle Related Topics (Non Year Related) 6 05-14-2007 12:01 PM
Sea Foam Brendan 95.5-2004 Tacomas & 96-2002 4Runners 33 02-24-2007 11:07 AM
Do you change oil after Sea Foam??? mtrdrms 86-95 Trucks & 4Runners 16 06-09-2006 11:18 AM
Deep Sea fish/creatures...WOW! Lotus1 Off Topic Talk 15 08-27-2004 04:52 PM
double wow wow Mudd Runna 95.5-2004 Tacomas & 96-2002 4Runners 23 04-08-2003 02:11 PM
2009 InternetBrands, Inc.
