woun't drive or run
Old 02-13-2009, 03:45 PM
chevy1one's Avatar
woun't drive or run
i have a 1993 pickup with a 22re my problem is when i give it gas i dies. at idle it runs strong! i just cant drive it. i have put on a new tps sensor and a new mass air flow sensor i. my guess is that i got a bad tps but i dont know how to test it to see if its any good, also the tps looks like it has a adjustment, how do you know where to adjust it? any advice would reall help thanks alot. also im getting a code 24 what would that be if i just replaced the mass air flow sensor
Old 02-13-2009, 03:49 PM
abecedarian's Avatar
check the boots and ducts from the throttle body over to the air-flow meter for any cracks or leaks yet?
Old 02-13-2009, 04:06 PM
chevy1one's Avatar
i did not see any cracks or such the engine was just bought as a new rebuild.
Old 02-13-2009, 04:22 PM
a new engine doesn't mean the rubber's are fine and just 'cause you don't see a crack doesn't mean it's not there- squish and sqeeze and check.
Guess I can't rule out having the timing set improperly either though.
How did you set the timing?
Charecter1
11-06-2023 10:08 AM
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: woun't drive or run
