wont start please help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-24-2007, 02:53 PM   #1 (permalink)
hi i just bought a 95 4 runner 3.0 auto. got it running with a fuel pump and it ran rough so i did a tune up oil, air fuel filters plugs, cap and rotor button. went to start and it would fire and die then no start at all. i am trying to fix this on a budget and dont want to have to take it to a dealer. if you can help me please do i will be very greatful. thanks jon
95yota4 is offline
Old 06-24-2007, 03:16 PM   #2 (permalink)
Yota4runner's Avatar
Send a message via AIM to Yota4runner Send a message via MSN to Yota4runner
You check your timing? make sure its set properly. Have you checked for Spark and fuel pressure as well?
__________________
[-Chris-]
1988 X-Tra Cab 4x4. V6. Stripped to the frame.
1998 Chevy Chyenne Extended Cab, pretty much stock, except for a few cosmetics.
Yota4runner is offline
Old 06-24-2007, 03:25 PM   #3 (permalink)
Corbit's Avatar
Will it fire if you use starting fluid ? Open the air box and open the door on the AFM with the ignition switch on and listen to hear if your fuel pump kicks on . If not you may have a short some where . You can also use a jumper wire in the terminals of the diagnostic box next to the main fuse box on the passenger fender. I think it's E1 to FC for the jumper. I'm not 100% there , you'll need to do a search to confirm.
Corbit is offline
Old 06-24-2007, 03:33 PM   #4 (permalink)
bruzer's Avatar
Make sure you didn't knock any of your air intake system loose, the 3.slows have a hard time starting if its not pulling enough air through the mass airflow sensor. I would also recommend checking your fuel pressure and spark. After changing the fuel pump it also can take a couple of try's to get it to start do to the amount of air that might of made its way into the fuel line.
Good luck and let us know what you find.
__________________
92 4 Runner, locked, swaped and linked.
www.utah4x4club.com
www.U4WDA.org
bruzer is offline
Old 06-24-2007, 08:35 PM   #5 (permalink)
Send a message via AIM to Schump
I had same problem-bad f pump relay.
I had the same problem ('92 V6 xtra cab 4WD), but i when pseudo-wheelin LATE one night when it was POURING down rain. the creek flooded over the road and I decided to put it in 4wd low and press on (don't worry, i walked through it first to make sure my truck wouldn't get waashed away!) anyhow, the idiot on the other side told me and my friend "you gotta go fast, you gotta have momentum...floor it."
i told him, "hey [dumbass] i have 4wd low, a V6, and i'm on pavement, in know momentum is good in snow but i don't think i need it...."
but this was the 1st time i'd ever put my truck in 4WD, and he claimed to have been wheeling a lot, so i listened to him. i made it across fine, but we hung out for a while, creek got higher, and i stupidly took his advice and floored it heading back towards home through the water. gulp gulp gulp!
after me and the tow truck driver pulled every bit of 250' of cable out of his truck and hooked it to the front of my truck (creek crested at 5am, water was about 8" above the bottom of my driver's side door, but 1/2" below the passenger door)
i got my truck home.
i had almost hydro locked it.
it would run for 5 seconds then die. my friend and i worked on it most of the day and i chased the wiring diagram and deducted correctly that the main fuel relay was blown. it's in the right kick panel just in front of the right door. if it's bad, the fuel pump will only stay on for 5 seconds. of course i called the local 4wd shop and they told me "oh, you CAN'T figure that out yourself! you need a computer and yada yada yada"
sorry guys, i ain't paying you to figure out something i can do myself. besides, i've never paid a mechanic a red cent, save for the 1/2 hr to tell me the ring gear in my 1985 maxima wagon w/ 223k on it is about to fall of the differential, and the mechanic was surprised he'd made it round the block.
i think this relay was like $65 at the dealer. you can jump it with a wire to see if it's the problem, truck should keep the pump running w/ the wire jumped.
see the back of your haynes manual for the wiring diagram.
and good luck!
Schump is offline
Old 06-25-2007, 08:04 PM   #6 (permalink)
thanks guys for the help checked the spark tonight by putting a plug in a wire hold it on head bolt no fire checked for voltage at the coil wire on dist. cap none then checked at the top of the coil where wire comes out for cap none. checked the wires going in to coil for juice and there is juice on both wires. thinking maybe its the coil any thoughs before i buy one. thanks jon
95yota4 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.0 wont start 4rnr 86-95 Trucks & 4Runners 18 03-19-2007 10:30 PM
Recently rolled 4-runner now it wont start, why wont it ?? gtpunk18 86-95 Trucks & 4Runners 22 01-24-2007 10:25 PM
it just wont start tk0218 86-95 Trucks & 4Runners 2 03-06-2006 05:50 AM
HELP!!!!!!!!!!!!!!!!!!Still wont start cobrahunter 95.5-2004 Tacomas & 96-2002 4Runners 4 08-08-2004 06:42 AM
wont start headhunter 95.5-2004 Tacomas & 96-2002 4Runners 8 02-02-2004 04:10 PM
2009 InternetBrands, Inc.
