It won't start
It won't start
Head gasket replaced, everything put back together, all connections, all the bolts... and now it won't fire.. Tried a different battery, replaced a terminal, tried jumping it off with both... It gets juice, lights work, radio works, gauges work, etc..
What is holding it back here? Starter?
'92 PU w/ 22RE
'92 PU w/ 22RE
thee things needed to start and run an engine..
air
fuel
spark
lots of things to check..fuel pump, injectors, wires, plugs, ignitor, distrib (dunno about 22re), AFM,
does it crank? check your connections. grounds often corrode and wont allow the engine to start.
air
fuel
spark
did you get your grounds all put back on? you have a starter problem - check corrosion on the battery terminals - wiggle the posts -- If you know you have a good battery, then something is ajar with your starter. - check wiring
