wiring help please 1st gen 4runner
hey people im in the prosess of turning an 86 toy p/u into a 1st gen 4runner i have the top post of the roof and the back of the floor from an 89 4runner im cuting the cab open on the 86 truck and then goin to weld it all to gether my problem is i have a wiring harness from an 86 4runner and my truck is carbed i want to keep the carb due to the lack of a ecm i want to keep it smple but i also want to get the rear window functional the only part of the harness i dont have is the stuff under the hood is there anyone that can help me decipher the wireing from the plug that that hooks up to the rear gate and switches any links or help would be greatly apriciated
Oh man, are you in luck!
You don't need any of that. It's real simple.
1) Run a hot wire from a power source under the dash. Or, just run one directly from the battery.
2) Pick a ground....any ground from under the dash and run a wire....
3) Run both of those to a splitter or splice so that you then have two of each to hook to a double pole/double throw rocker switch mounted at a select location on your dash or console.
a) On the switch, you will have two poles on each side and two in the
middle.
b) Take one power and one ground, hook them one end, swap the other power and ground and hook them to the other end. The two terminals in the middle of the switch are the sending wires that you run to the window motor. Like this:
s s
As you can see, the polarities are switched so that when the rocker is pressed one way the window goes up and the other the window goes down.
4) The sending wires can go to either side of the connector of the motor, if I remember correctly. If it doesn't work that way, you'll know and therefore just swap them around.
Make sense?
Note: This method "hot wires" the window directly to the battery. It's safe and I've had my '86 4rnr working like this for years. The only draw backs...if you believe them to be....is that there are no safety features as would be with the factory set up (the window will operate whether the gate is up or down) and you'd therefore have to be a lot more careful. Also, there is no provision in this for operating defrost or the rear wiper, if those are important to you. Nevertheless, the window will work.
middle.
s s
Make sense?
thank you for the help i would acualy like the rear window and wiper to work properly but i will take your idea into concideration if i cand get the factory way to work
Well, for the wiper, you'll need the relay board that goes in the body cavity behind the driver's seat. Do you have that?
well i have an entire wiring harness from an 86 efi runner front to back i think ill be swaping the carbed harness to the efi i think i have all that i need all relays and everything thanks for your help
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
