Wiring Harness for Speed Sensor
Old 07-12-2012, 06:35 PM
Brokenstuff's Avatar
1995 4Runner 3.0, 4X4 auto, speed sensor harness, leaks where it enters the trans. Is this connection at the trans, suppose to have any rubber grommet on the outside? Mine has none. It has an O ring half way down the fitting but it seems to have really no effect on stopping the trans fluid. Anyone have a drawing or schematic of it? Don't know if the entire harness needs to be changed or what?
Old 08-29-2012, 07:04 PM
StewsRunner's Avatar
Hey can I ask where the speed sensor is located on the tranny? Is it accessible with out dropping it?
Old 08-29-2012, 08:54 PM
scope103's Avatar
Here's the drawing from the Manual. I don't know if that will help you at all.
Old 08-29-2012, 08:58 PM
So looking at the picture for the no. 1 VSS, it looks like that is right next to the drive train going to the rear, right below his wrist? Is that correct? I just saw this picture and it looks about the same,
After reading a couple other threads I understood that 92 is the first year to use the VSS? So what about 91 and below, if my info is even correct.
MO transplant
04-23-2023 11:58 AM
sandyota
02-04-2021 11:16 AM
msane99
07-17-2015 10:13 AM
88yodabasket
07-13-2015 01:32 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Wiring Harness for Speed Sensor
