Wiring Harness on a 3VZE motor question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-09-2007, 07:13 PM   #1 (permalink)
I'm swapping out my 3vze with blown head gaskets with a motor from a wreck and my question is can you remove the wiring harness with the motor from the truck? It looks to me like the plenum will have to come off first and the wiring harness disconnected from all the connections and then pull the motor. That will be a royal PITA if that's the case. Any help is appreciated, thanks! I was hoping that the harness would unplug somewhere but for the life of me I can't see where.
stinger381 is offline
Old 04-09-2007, 07:30 PM   #2 (permalink)
Send a message via AIM to justinking060310
you need to go under the passenger side kick panel and unbolt the ECU and unplug your connections there and then up in the engine bay you can pull the wires through.... Make sure you get at least one good harness out of the deal eh?!
Kat
__________________
95 4runner 2wd 3.0 v6
Downey headers (dont buy them)
Downey 2 1/2" full exhaust/Carsound cat
Weasy2k cams/ENGNBLDR's o/s valves
ported and polished heads/intake
New project- 94 4runner
V6 4x4 A/T
3" 4Crawler BL on order
33x12.5 BFG A/T's on 15x8 Cragar Black Steel Wheels
90 4runner 4x4 3vze Auto
parting out - let me know if you need anything!
85 4runner, SFA, 22re, 5speed parting out
justinking060310 is offline
Old 04-09-2007, 07:52 PM   #3 (permalink)
same as above but dont forget to disconnect the wiring from the trans, transfer case and o2 sensor
1994runner is offline
Old 04-09-2007, 08:03 PM   #4 (permalink)
toyota_mdt_tech's Avatar
Quote:
Yes, it will unplug just inside the firewall on the engine ECU, remove the entire harness w itht he engine. One leg will run down the transmission ot the oxy sensor, but easier to leave the harness on the engine. What year is your rig and what year is the engine going into it?
__________________
Toyota Master Diagnostic Technician
"MDT"
1998 Toyota Tacoma TRD V6 4WD 5 SPD
1998 Chevrolet K1500
1999 Toyota Camry
2003 Toyota Highlander 4WD
2007 KTM 85SX 17/14
2006 KTM 300XC-W
2005 KTM 65SX
2004 Kawasaki KLX 110
2003 Honda XR50
2002 Yamaha TTR 125L
2002 Kawasaki KLR650
2002 Suzuki Eiger 400 4WD
2004 Cargomate<--link
GeePaw® Racing<--link
toyota_mdt_tech is offline
Old 04-09-2007, 09:09 PM   #5 (permalink)
it is a 1995 4 runner and the motor came from a wreck of thesame year. That is a big relief to me now. I think I can probably handle that and get that harness out now. The one off of the wreck motor is cut and useless to me and the plugs were dry rotted and brittle. I hope that the harness on the truck with the old motor will be better. It has a 5 speed manual transmission with four wheel drive also if that matters.
Old 04-10-2007, 07:13 AM   #6 (permalink)
Well this solution will work out for me much better too as the motor that I have came out of a rolled over 4 runner with about 80,000 miles on it and the engine compartment was so messed up that the wiring harness was just cut to get the motor out of the wrecked truck. So I only have this one wiring harness to play with and I CAN'T mess it up. It has to come out in tact and be salvageable and be reused. I'm scared that all the plug ends on the fuel injectors are going to be brittle like they were on the wrecked motor and they are going to crack and break and then I'm going to have to buy a new harness anyway.
Tags
110, 125, 2000, 2007, 3vze, 400, atv, eiger, engine, harness, klx, parting, pull, suzuki, toyota, ttr, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Identifying 3.4 Motor and Wiring Harness? yotaman The Fab Shop 3 06-27-2007 06:49 PM
90 3vze engine, wiring harness/computer, & R150F 5spd trans, Orlando FL. Anubiscougar The Classifieds GraveYard 4 01-23-2007 02:47 PM
radio wiring harness question rickgoof Vehicle Audio & Home Entertainment 6 09-04-2005 08:58 AM
Wiring Harness Question bcr308 Vehicle Audio & Home Entertainment 1 12-11-2004 07:20 PM
2009 InternetBrands, Inc.
