wiring harness
Just what year truck did the doors come from??
People have said the connectors for the door harness should be up under the dash. Be a little stupid to have two cab wiring harnesses the only difference being power windows and door locks
With the Toyota electrical manual for your year truck you should be able to make it work
Guys who are doing this swap in the 90's version truck are not so lucky. Though this doesn't happen every time some harnesses are missing the wire from the tach, yet other harnesses are have this wire. I've heard it said "It's the luck of the draw", there doesn't seem to be any rhyme or reason for all of the harnesses not being the same!
If you got the doors off of this other truck, it's a bit more work but I'd get the door harnesses off of it as well, but that's not all you need. There is also a door control relay located under the dash on the firewall left of the clutch pedal (if you have one). It ties into the integration relay and is fed from the 30a. cassette fuse. You will need that and the associated wiring.
Just to let you know; where you just joined YotaTech that you will probably get a frendly message from one of the Moderators or Administrators about double posting. You already made this post in the "General Electrical and Lighting Section" you don't need to make the same post again in another forum, so this one will probably be deleted.
