Wiring
Old 06-02-2009, 01:35 PM
Tom2000t4r's Avatar
Wiring
91 4runner 3.0
Horn wire: someone unhooked the horn on the pass side ( IS THERE SUPPOSED TO BE TWO HORNs?) Anyway I cannot find any wire anywhere close that it should connect???
Mystery wires: Looks like this harness was yanked out of whatever it connected to. One wire is black the other is yellow with a red stripe. This is in front of and below the coolant reservoir. WHAT IS THIS WIRE?
Old 06-02-2009, 05:12 PM
Tom2000t4r's Avatar
Anybody know?
Where the wire comes out of the harness for the horn?
What are the mystery wires?
Thx
Old 06-02-2009, 05:20 PM
Tom2000t4r's Avatar
THE two wires look like they'd be in about the location to connect to the driv side turn signal but it works fine
Old 06-03-2009, 05:42 PM
Tom2000t4r's Avatar
bumpp
Old 06-03-2009, 06:10 PM
RMA
RMA's Avatar
Dude , there is a black cylinder for the AC , I dont know the name of it but any way that black cylinder has a small little glass on top to see the freon.
about 3 or 4 inches away from the cylider along the aluminum hose there is a connector .
this wire looks like it was connected there.
right above in your last picture.
I will go out to my truck and double check.
Old 06-03-2009, 06:16 PM
RMA
RMA's Avatar
The connector next to the cylinder
Old 06-04-2009, 11:56 AM
Tom2000t4r's Avatar
Thks RMA, it right next to that plug but not it. The harness Y's out there and it's the other end of the Y. Black wire and White wire w/ red stripe.........any idea??????
Still lookin for that horn wire also if someone knows??????????
Old 06-05-2009, 05:25 PM
Tom2000t4r's Avatar
bump
anyone mind checking your own truck for me to answer these ???
Again:
---horn wire location????
---mystery wire harness????
Old 06-06-2009, 07:45 PM
Tom2000t4r's Avatar
bump
Again:
bmppp
Old 06-06-2009, 08:31 PM
RMA
RMA's Avatar
Here you go its a little black box aroud 1" x 2" big right under the black cylinder (dryer).
Old 06-07-2009, 06:43 PM
Jay351's Avatar
WHy don't you just trace the wires and find out where they go. If they go into a main harness then its probibly factory.
If not it might be something that was on there in the past.
Old 06-08-2009, 07:08 PM
Tom2000t4r's Avatar
thx man, looks like some sort of temp sensor
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
ToyoToler
08-08-2015 08:43 AM
Daneums
07-28-2015 11:57 AM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Wiring
