wires that are hot when engine is running
Old 09-18-2008, 11:46 PM
Matt16's Avatar
I need a wire to draw power from to throw a relay when the engine is running.
I have a York belt driven compressor (on board air) with a magnetic clutch. I want to make it impossible to drain the battery by leaving the clutch magnetized with the engine off. Thus, I want to find an easy-to-access wire that is hot ONLY when the engine is running.
The only option I've thought of, that's easy to get to is the daytime-running-light circuit.
Old 09-19-2008, 06:48 AM
wardriver's Avatar
Only when the engine is running or only when the key is in the right most position? If it is the 2nd then if you feel like fishing a wire through the firewall you could pig tail off of the back side of the cig lighter - the main wiring harness isn't too hard to get to either. You just take off the few screws and the 10mm bolt under the steering column. You could easily find a keyed wire there.
Or were you hoping to locate one under the hood?
Old 09-19-2008, 09:19 AM
Matt16's Avatar
Ideally under the hood, cause that makes my life easy.
Old 09-19-2008, 09:53 AM
annoyingrob's Avatar
Pull power from the fuse box. The Black/yellow, and Black/orange wires should be powered only when the key is in the accessory and on position.
Old 09-19-2008, 09:54 AM
Matt16's Avatar
I didn't know that colour code was in effect, that's awesome.
Old 09-19-2008, 10:14 AM
space-junk's Avatar
or, you could always just pull from the stereo harness...
Old 09-19-2008, 10:20 AM
I think all toyotas use the same wiring colors
Old 09-19-2008, 12:06 PM
Matt16's Avatar
It's a pain in the butt to pull wires through the firewall. I like the fuse box idea better.
Team420
01-12-2021 04:57 PM
B. Graves
07-03-2015 04:10 AM
sonic concepts
07-01-2015 02:33 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: wires that are hot when engine is running
