wipers don't work
1 Post
check at the wiper motor where the plug is they can get full of corrosion man i cant spell but just look at the connections and see and make sure there clean thats about it that i can think of right now
(used spell check man you had no idea lol)
1 Post
yeah get a test light or a multimeter and check the wires at the motor and see if your getting power to it or not if you are then its the motor if not then its going to be the switch or a broken wire or fuse
i ran a hot wire to the motor and it worked, also tested my switch and it tested good. the plate for the fuses is gone on mine so i checked all the fuses, which one is the wiper fuse? 91 pickup
aciorba23
06-29-2015 04:18 PM
cchinny
06-25-2015 08:11 PM
