wiper linkage bushing - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-20-2010, 11:12 PM   #1
desert-rat660's Avatar
well my wiper linkage bushing broke into pieces on the motor side> priced it from toyot its about $260.00. i went to the wrecking yard but all the plastic seems to be brittle so i said screw it. I dont know why toyota doesnt sell the bushings. anyways i decided to make my own linkage i used a piece of 1/2 steel tubing and got 2 5/16 heim joints, i bent the tubing to match the factory piece and welded nuts to the end of the tubing and threaded the heims in, works like a charm and only cost me $15.00. i did have to grind the factory pivot balls off the arms, i ground were they are riveted to the arm then used a punch to drive them out, used 5/16 bolts to hold the heims
welds werent the best but they will do the job
http://i535.photobucket.com/albums/e...660/002-24.jpg
desert-rat660 is offline   Reply With Quote
Old 07-20-2010, 11:32 PM   #2
stoicheg2's Avatar
I had that problem with those stupid plastic bushings.
Great job on that linkage!
stoicheg2 is offline   Reply With Quote
Old 07-20-2010, 11:33 PM   #3
thanks!!!!
Old 07-25-2010, 07:56 PM   #4
Hi,
I'm having the same exact problem. The dumb thing just snapped off. Why don't they make these out of metal? Gah.
So, did you make some sort of socket type of thing that the pivot arm sat in? I didn't really get a good look at the thing before it snapped to pieces.
Thanks
georghammond is offline   Reply With Quote
Old 07-25-2010, 08:02 PM   #5
Licensed Lunatic
iamsuperbleeder's Avatar
that's a heavy duty wiper linkage there, holy crap!
lol
nice job!
iamsuperbleeder is offline   Reply With Quote
Old 07-26-2010, 06:57 PM   #6
I found these wiper linkage pieces. Not sure if they work. Ordered one up. Will let y'all know.
http://shop.advanceautoparts.com/web...=24-93823641-2
http://shop.advanceautoparts.com/web...=24-93823785-2
Old 07-26-2010, 09:35 PM   #7
OutlawMike's Avatar
Let us know if they work, my wipers are clicking and the bushings look to be very loose right now.
Thanks,
Mike
OutlawMike is offline   Reply With Quote
Old 07-29-2010, 03:46 PM   #8
Ya, I got them in. I'm not sure if they're going to work yet though. They might be too small. I'm not 100% sure how the bushings are supposed to connect to be honest. You get about 4 bushings with heads on them and one bushing w/out a head. Not sure if the one w/out a head is supposed to go in the one with a head or what.
If I figure it out, I'll post back here.
later,
george
Old 07-29-2010, 04:56 PM   #9
slacker's Avatar
all well and good .. but used wiper transmissions/links are a dime a dozen .. I just tossed 2 this week because I was tired of tripping over them
slacker is offline   Reply With Quote
Old 07-30-2010, 06:36 PM   #10
Hey man,
So I'm thinking it's a no go for those bushings. Don't seem to work too well. Not sure if they're the wrong size or what, but they're a real pain to get on and they don't stay on once you get em on.
So, I'm going to Plan B. Picked up a copper piece at home depot. It's kinda like a copper pipe that widens at the end. Widens into a screw. I think the widened part of the piece will fit into the wiper arm and then the copper pipe piece fits nicely onto the ball joint on the wiper motor. All I'll need to do then is crimp the copper piping around the ball joint and hope for the best. Will report back if this scheme pans out.
Old 08-04-2010, 07:22 PM   #11
the ball that the bushings snapped over, i just used a grinder and cut them off, then took a 5/16 bolt and groung the head almost flush to clear the other linkage arms, used a couple washers under the heim put some thread lock ont the bolt and was done. yeah i know the junkyards have cheap wiper transmissions, but they too had stress fractures forming in the plastic so its only a matter of time before they cracked. plus i live in the 120 degree desert so plastic doesnt last out here.
Old 08-07-2010, 08:29 PM   #12
Ya, I just used a piece of copper piping. Put it over the ball socket. Pinched one end down around the ball and cut 3 slits in the other side. Then I put the copper piping into the arm and pulled the 3 slits out so it stays within the arm. Worked like a charm. (a little noisy, but I can deal) kinda looks like this: 3=
the = sign being the unmolested copper piece that's wrapped around the ball and the 3 being the slits of copper that were pulled out so that it stays within the wiper arm. Not sure if that makes sense, to anyone but me.
Joe's 1987 4Runner ladybugRC 86-95 Trucks & 4Runners (Build-Up Section) 344 01-19-2017 12:41 AM
Distance vertically between oil pan and highest part of axle housing? live4soccer7 84-85 Trucks & 4Runners 3 05-11-2016 07:52 PM
94 22re sr5 4Runner clutch and shifting issue punks_is_4x4 86-95 Trucks & 4Runners 1 02-26-2016 05:29 PM
FS[MidAtl]: 1979-1983 Pickup Parts For Sale - Post Build Garage Clean Out kawazx636 Vehicles - Parting Out 31 02-23-2016 12:57 PM
94 4Runner with back door open and glass stuck UP PNW94Runner 86-95 Trucks & 4Runners 3 09-29-2015 03:55 PM
Tags
78, 91, assembly, ball, bushing, bushings, joint, linkage, mechanism, part, pickup, toyota, truck, wiper, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
