wining noise
wining noise
i have a 93 4runner with a whining noise. i just bought this truck and i have a whining noise while under load. any speed. its an auto i put it in N and the whinging goes away. its only under a load any clues?
If its up front it could be a few different things. I take it is a 3.0? Alt. could be a possibility but have you changed out the t-belt lately? Could the tensioner be causing the noise?
this is why im stupified it doesnt change with the revs of the engine doesnt do it at any speed while coasting in N im stuck trying to locate this
be sure & confirm thats where 1st.then just for giggles i would change the fluid & put in synthetic lube.if it has just started the noise it will go quite a while before you absolutely have to replace.when it is time you may be able to find a good used 3rd member & just change the unit out.or if you want to change ratio or add a locker this would be the time to do it.i just happed to have 2 3rd members used if they are the right gear
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
