windshield washer pump(s)
Old 06-08-2006, 06:17 PM
frankjake's Avatar
Anyone replace the pumps with the universal aftermarket pumps you can buy at Napa or any of the other major auto parts stores.
The pumps from Toyota are $50 for the front (bottom) and $80 from the rear (upper). The universal pumps from Napa are only $15. It looks like all you need to do is splice the wires as the new pumps don't use the exact same connection plugs as the original.
Anybody tried this?
Old 06-08-2006, 06:29 PM
eric-the-red's Avatar
I did years ago, can't even remember which vehicle it was, but it worked fine
Old 06-08-2006, 07:53 PM
regularguy412's Avatar
Universal works great for me. I think it was $12 from Advance Auto. Took a whole 10 minutes to install.
Mike in AR
Old 06-08-2006, 08:54 PM
InternetRoadkill's Avatar
You don't need to go to a universal type. You can get an exact fit replacement for under $20. Or you can move the rear pump to the front. It will fit. All you have to do is splice the wires to it.
Old 06-08-2006, 08:56 PM
4x4Lamm's Avatar
I had a great experiance replacing one of mine in a 92 4Runner with the cheap model from Auto Zone. I don't think it was universal though, they had to look it up by year, engine type and everything and it fit perfect.
Lamm
Old 06-08-2006, 08:59 PM
trythis's Avatar
I tried the 13 dollar one from advance and had to return it. THe barb was too small and too short to hold the hose, so I would have had to replace the hose too. The dealer wanted 26 dollars at the time, and to wire it I would have had to cut the wiring on the truck and splice it into the wires on the generic, it wasnt worth the time and hassle.
I bought the dealer's, clipped right in.
Old 06-09-2006, 05:01 PM
Adam F's Avatar
I just put a replacement pump from KOI Auto Parts on my 95 Pickup 22re 2wd. I just had to splice the factory wires, and put the included bushing on the washer reservoir, and it works great. Fit perfectly.
Old 06-09-2006, 05:36 PM
frankjake's Avatar
I went to Napa and they only had 1 of the replacment pumps. It did not come with the rubber gromet. Then I checked with a few other local name parts stores and found 1 more, the brand was Trico and had the same number on the pump as the one from Napa but the Trico came with the gromet. So I bought a 2nd gromet that was for a PCV vavle and it worked perfectly. I did have to splice the wires but the whole job took less than an hour.
Thanks for the info guys.
Old 06-09-2006, 06:38 PM
LOCKnGO's Avatar
Mine just fell apart last week. It fell of the botle in three pirces We have a direct replacement for around $20.
mussy01
12-13-2016 08:20 PM
09-04-2015 09:27 AM
gmonnie123
07-26-2015 02:44 PM
msane99
07-17-2015 10:13 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: windshield washer pump(s)
