windshield problem
Old 11-10-2007, 07:37 AM
InternetRoadkill's Avatar
Question windshield problem
I removed the windshield from my 4R as part of my repainting project. Now it's time to put it back in. So I get my razor blade out and try to scrape the old primer and adhesive from the glass so it can be re-glued. Most of it came off, but there is still some left behind that the razor won't remove. Now I got a problem. I can't install the glass until the old primer and adhesive is removed. I tried every solvent I could find in my garage and nothing will touch it. Not mineral spirits, acetone, alcohol, toluene, or xylene.
Arrrgghhh. How do you get the old urethane and primer off the glass?
Old 11-10-2007, 08:20 AM
CyMoN's Avatar
heat gun or a propane torch just don't get it too hot
Old 11-10-2007, 08:46 AM
Heat gun doesn't do anything. I got the glass too hot to touch and nothing. It appears that the urethane primer is what's refusing to come off.
Old 11-10-2007, 10:37 PM
stormin94's Avatar
Try some carb cleaner
Old 11-11-2007, 02:25 AM
TORTIS's Avatar
try some of the adhesive that you are going to use to hold it in, if it does it break it down then it should seal up and hold. maybe a drill and wire brush, or a grinder.
disclaimer 1. wear a mask and eye protection
2. tortis is not in any way a windshield expert, and has been known to
give bogus advice.
Old 11-11-2007, 06:00 AM
I got it off... finally. The problem was crappy razor blades from walmart. They were going dull almost instantly. I never did find anything that would dissolve the primer. It's really tough.
09-04-2015 09:27 AM
TDonkey
07-26-2015 10:14 AM
Jonny246
07-24-2015 12:37 PM
chickenhala
07-21-2015 05:41 PM
msane99
07-17-2015 10:13 AM
Quick Reply: windshield problem
