will the ZUK coil mod help level m y rig from side to side?
my rig is leaning alot to the drivers side thinkin of doing the ZUK mod but not sure if it will work. any thoughts would help.
OK so im a newb, but know what the zuk mod is just dont understand the point of it over just replacing the leaves, any info.. the rear of my 94 pickup sags a little compared to the front.
to the OP...i think if the torsion bar adjustment doesn't work, then you will have to get something like a 14" 100lb coil for the passenger side..and a 14" 125# coil for the driverside LOL
make sure you dont have a broken leaf. Might just want to replace thoes also.
Edit: what are you running in the back? lookl like a block/antiwrap bar?
I recall that two of the guys that did install the coils did report that it rode a ton better AND took the lean out they had. So, it might fix you up. Be aware that lean can be caused by not only a tired leafpack but also by a bent shock or even a curved leaf perch. ZUK
1) It gets the rig up to (or above) factory ride height depending on the coils.
2) Coils don't sag over time.
3) The spring rate of the coils cuts down the body roll.
4) The coils offer a better weight capacity.
Just so you don't think I'm talking out of my @$$
https://www.yotatech.com/forums/f116...ks-zuk-157035/
In my current rig I haul close to 400lbs of gear on a camping trip. Camping box, spare fluids, spare parts, spare everything and it carries that weight with no issues.
OP. Your rig looks to have either a busted rear leaf pack or an issue with the TB on the drives side. With that kind of lean I'd be doing a complete inspection of the suspension mounting points on the frame and a serious look at the rear packs.
icentropy
07-11-2015 07:21 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
