Will this work?
Will this work?
I have a 91 pickup with a bad 22re, but i found a 83 celica with a running 22re what i'm wondering is will this motor work in my truck, wiring harrness and all?
Oil pans are different
Fuel injection is different
Intake is different
Exhaust is different
Long and short of it is, no, the 83 celica engine will not work. Sure it will physically fit, but thats about it. You wont be able to use the 83 stuff, and the 91 stuff wont swap to the 83 engine.
Intake is different
I could be wrong. But I thought if you stripped the celica motor down to a long block and used the truck stuff on it then the swap would work. When I was thinking about replacing the engine in mine I found a lot of places that made no distinction between the two. Seems to me that the long blocks were the same, you just had to swap all the other stuff from car to truck. That also explains all the extra holes that dont get used in the block and head. Maybe they do get used on the car install.
You can find other 22RE's around if you don't want to go with a new/rebuild. Check craigslist.org. I saw one for $300 on my local site and I didn't think anybody else had them around here!
Rob
Rob
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
