will this work?
will this work?
well I am having the infamous stumble,shuddering,misfiring,ECT.
that so many othermembers are having BUT only when it rains.
sooo I think it may be the mass flow sensor so I went to the u pull and pulled a MAF off of a 88 camery and one off a 88 pickup.
the pickup was a 22re also grabbed the igniter coil from the truck.
now I have a 3.0 and wondered if anyone has switched MAFs from different motors the one from the camery looks exactly the same as mine
also got some lockout hubs some idiot busted the switches out with a roofing hammer but the main hub part was still good.
dont really know about the MAF but look at the part numbers, are they the same? My 91 PU 22re is running with a TPS off of some camry 6 cylinder right now. The part numbers were the same and it runs good.
If that helps any.
Jim
If that helps any.
Jim
cool ,one set of numbers are the same but the second set are different.
I guess if I switched them and ran the truck I will find out real quick also, but I was hoping that some one knew already instead of my truck being a guinea pig.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
