Will the W50 bolt upto a 22RE?
I have a '93 standard 2wheel 5speed with a 22RE and a W55 trans. Long story short.... My truck is a daily driver and I can not be down for repairs so looking to swap trans. I have leaned ALOT about Toy trans in the past week. Mainly every trans I have bought is not the right one. Will a W50 bolt upto a 22RE? It has a W55 in it now and from what I can tell everything "looks" close like the rear mount, slave cly ect... The bell housing is the question and the length of the input. From the info I have found both have a 21spline x 29mm input and tail shaft 21 splines. The gearbox length is the same @ 22" so the drive shaft has to be the same length. This swap is only a temp fix and not intended to be run for a extended time but only long enough for me to rebuild my W55 and get it back in there. Let me know what anyone thinks!!!!! P.S. I will have a W50 and a W56 (4wheel) trans that I will not neeed after this is over if anyone can use them.....
09-04-2015 09:27 AM
TransAmBandit
07-28-2015 11:30 PM
