will they fit alright?
Old 06-08-2009, 06:21 PM
bwiygul's Avatar
just wondering because i'm looking at some wheels/tires a guys selling and i don't have a lot of time cause he's holding them for me but i have a 93 pick up and i'm going to put the ball joint spacers and the zuk spring mod on the back, will i be able to fit 33's in comfortably? thanks.
Old 06-08-2009, 06:32 PM
bwiygul's Avatar
oh yeah, i'm looking at about 1.5/2" lift from stock. thanks.
Old 06-08-2009, 07:25 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Fairly comfortably.....yes
Old 06-08-2009, 07:35 PM
bwiygul's Avatar
thanks
Old 06-08-2009, 07:40 PM
abecedarian's Avatar
like 'freak said, the tires will fit with the bj spacers. however, a good bump may cause the tires to rub since compression travel is limited by the lower control arm / bumpstop. bj spacers push the wheel down / frame up but don't do anything to limit the up-travel of the wheel any more than what stock wheels would experience.
Old 06-08-2009, 08:07 PM
bwiygul's Avatar
cool...i appreciate it...i'm just getting some pretty nice american racing rims with 33" bfg mud terrains...guy needs to make rent so it's 250 for the set. i was planning on either running them till i need new ones or take em off and throw 31's on. not sure yet i'll see when i get em on. either way, it's mostly daily driver with the occasional off roader but mostly gravel and dirt. so hopefully they'll be alright...oh yeah, since i got you guys how bad will 33's hurt my power and mileage? will i need to re-gear the rear end? how about 31's? thanks.
Old 06-08-2009, 08:16 PM
Fossilized
Staff
dropzone's Avatar
Originally Posted by bwiygul
will i need to re-gear the rear end?.
if your '93 is 4WD you will need to re gear the front end too
31's would not affect your truck nearly as much as 33's will impact your power/mileage...
Old 06-08-2009, 09:43 PM
bwiygul's Avatar
so, one other tire question...the tires on the rims are 33x12.50x16.5.
do i have to get 16.5" tires? or will 16's work?
Old 06-10-2009, 02:26 PM
Fossilized
Staff
dropzone's Avatar
if you have a 15" tire you need a 15" wide rim
if you have a 16" tire you need a 16" wide rim
if you have a 16.5" tire you need a 16.5" wide rim
16" tires say right on the side 'Don't mount on a 16.5" Rim'
Old 06-10-2009, 02:31 PM
Lumpy's Avatar
33's should fit without the spacers but you have to watch the saggy butt as I found on the 4runner. I know yours are going on a pickup...
Check out this thread.
https://www.yotatech.com/forums/f116...-guide-155339/
Then...Oops
http://i714.photobucket.com/albums/w...py_91/Flx6.jpg
Didn't feel like posting the picture so I just gave the link. They fit fine in the front.
Corvoid
12-11-2015 11:21 AM
chuckd83
09-14-2015 03:20 PM
ac7822
09-12-2015 06:57 PM
dbd6604
09-09-2015 12:25 PM
anniesball
09-05-2015 08:45 AM
Quick Reply: will they fit alright?
