will my 3vze afm work on my new 22re?
just got an 87 xtra cab for a hundred bucks but the afm is missing. i got it to fire up dumping some gas down a vacuum and it sounded pretty rough so i was wondering if i could temporarily rig my 3vze afm on there to see how it runs befor i put any time or money into the motor.
thanks for the help i didnt figure it would work good if it did work but the plug looks the same so mabey ill get time to try it out tommarow. and thanks olharleyman i might i really want to see if its worth any time or money tho first cuz ive got a low miles 20r that runs real good that im considering dropping in there
tried it out tonight turns out it does not work but a 22re will somehow run with no afm at all. after messing around with it i found a blown fuse replaced that and now it will fire right up and idle but obviously the throttle response is horrible and itll cut out and die randomly but does run.
MMA_Alex
25
04-18-2017 05:07 AM
