Will a malfunctioning EGR cause a strong gas smell - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 04-05-2006, 06:29 PM   #1
A month ago I noticed a strong gas smell coming from under the hood. I change the carbon filter and it seemed to have went away. Today I filled up the gas tank (gas light was on) and the strong smell came back again. Seems to be coming from the passenger side again. Will a bad EGR valve cause this?
jjenks0 is offline   Reply With Quote
Old 04-05-2006, 07:08 PM   #2
wrenchmonster's Avatar
Nope, I suspect it's probably your canister again. Sounds like you may be overfilling the tank, which would cause the evap line to pick up solid fuel instead of vapors, and thus raw gasoline into the charcoal canister.
wrenchmonster is offline   Reply With Quote
Old 04-05-2006, 07:21 PM   #3
2nd what Wrenchmonster said. Don't fill it all the way up the filler neck.
Mike in AR
regularguy412 is offline   Reply With Quote
Old 04-06-2006, 06:25 AM   #4
I was wondering if filling the tank had something to do with it.
Thanks.
Old 04-06-2006, 11:20 AM   #5
I had a leaky pressure regulator on my fuel rail a few years ago. Of course, the smell didn't go away for a while and come back, it was consistent. Anyway, fuel leaks are usualy pretty easy to spot, if it's been going on for a while you'll see a yellowish residue wherever the gasoline had been deposited. In my case, I had it slung up by my belts and across the underside of my hood, all down the front of the block and all over the front of the intake manafold. I tried tightening the regulator down, no go. Replaced it with a used unit from one of my dad's old trucks and it hasn't leaked since.
Of course, I'm just babbling, sounds like gasoline coming up the vapor line.
SporkTek is offline   Reply With Quote
Old 04-06-2006, 11:33 AM   #6
AH64ID's Avatar
I thought there was a return line from the canister to the gas tank to prevent that?
AH64ID is offline   Reply With Quote
Old 04-06-2006, 01:16 PM   #7
Might be plugged or kinked. It's worthy of investigation.
Old 04-06-2006, 03:53 PM   #8
Quote:
No, there is no return line. Maybe you are thinking of the fuel rail return line?
However, your post does bring up a very good point. If your control line (from canister to intake) is stuck open, this can also cause the gas smell you describe. Esentially, the line stays open all the time, so there is applied vacuum at all times and while your gas is sloshing around, the evap line will pick up gas. So check your control which is either vacuum or solenoid operated.
Your evap system design changes things, as modern systems have vent valves and non vented gas caps and what not. But I won't go into depth with that just yet.
That reminds me... What is the condition of your gas cap? Is it the correct cap for your vehicle?
Rough idle mystery Eggslinger 86-95 Trucks & 4Runners 16 01-19-2016 08:20 PM
New member fighting a 3vze--idle, timing, mixture Blamalam 86-95 Trucks & 4Runners 16 09-26-2015 09:16 AM
22re complete exhaust: please advise tj884Rdlx Newbie Tech Section 25 08-28-2015 01:04 PM
Code 25 issues raptor510 86-95 Trucks & 4Runners 18 08-19-2015 03:15 PM
84 Toyota weber flooding mikeyd6789 84-85 Trucks & 4Runners 3 08-04-2015 12:51 PM
Tags
4runner, 91, bad, county, cousing, egr, fuel, gas, malfunctioning, smell, solenoid, strong, vacuum, valve, ventura
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
