Will custom '85 bumper fit '95 pickup?
Old 04-30-2013, 08:26 AM
jharper88's Avatar
Will a custom bumper made for a '85 pickup bolt up to a '95 pickup? If not could I weld another bracket on it to make it match the '95 bolt pattern?
Old 04-30-2013, 10:16 AM
Staff
Terrys87's Avatar
Stock 84/85 bumper brackets are different then 86- 88/89 trucks and 4Runners in stock form, so you are going to a different generation of trucks with the 95. You are going to have to fab up a bracket for this to work. Even being a custom made bumper, it was made to fit 85 it will not the 95 unless you have some special made bumper that was made adaptable which I am unaware of.
Solid axles and IFS have different length brackets. I think it is the IFS which actually has the longer brackets. One is definetly longer, just not dont remember which one it is.
Old 04-30-2013, 11:48 AM
jharper88's Avatar
So the bolt holes will not match up at all on the '95? The guy said it would bolt on his '92 but only w like 4 bolts. So I would need to put a hole new bracket on the bumper correct?
Old 04-30-2013, 01:06 PM
wyoming9's Avatar
Red face
If you can weld you will figure it out.
i put a SFA bumper on a 2000 Tacoma.
Just make all new brackets for the bumper.
Being careful to get the distance correct for a good fit.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
lledwod
08-30-2016 01:03 PM
toyoda8488
07-05-2015 10:18 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Will custom '85 bumper fit '95 pickup?
