| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Will bed from '89 Xtra Cab fit '88 Xtra Cab?
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#2 (permalink) |
It may mount but will look funny. The 89 is wider by a few inches so it will stick out.
#3 (permalink) |
yes.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#4 (permalink) |
Here is another one:
The widths look to be the same to me. Rob
__________________
#5 (permalink) |
I just put a 3rd generation bed on mine...The 3 bolts on each side towards cab will line up on your 88 but the back 2 on each side won't...The tail light plug-ins are the same...plug and play...
The licences plate lights plugs are different from 2nd generation and instead of splicing the the quick release style of the new bed...i just marked holes from old licence plate light and screwed them on in same location... The licence plate light wires are tight since bed is a little wider...Do not tighten any bolts till you use a straight edge and a tape measure on both sides and the distance between bed bulk head and back of cab...Once there the same on both sides (Bed will stick out around 3/8 of an inch on both sides of cab)...Tighten bolts...I used threaded shock stud bushing and thick washers on the bottom because the old rubber ones were shot and just tighten them up till they were squished... And the fuel tube mounted on the 3rd generation bed is smaller than the 2nd so I just tighten them up tight...there are 2 hoses but they do work...Any questions let me know...Good luck... John...
__________________
1984 gray Toyota xtra cab 4X4 pickup...Stock truck right now...Mods on the way... First mod (If you can call it a mod) is fixing the rust...Just Installed used Aisin manual lockouts...Junked those auto ones...Added RCI 2950 CB and Wilson 1000 antenna...Put a cage in back to haul rott around |
#6 (permalink) |
Why are his tail lights upside down? I've seen a few personally around here since I'm sure 99.9% of all Wisconsin 2nd gen truck beds are completely rotted through by now. The body lines are a little different between the generations and they dont match the cab perfectly but it works.
__________________
R.I.P. 1994 x-cab DLX 4WD 22R-E 5-speed: 31x10.5 Treadwright Green Diamond OTR | SR-5 Wheels, Cluster, Steering Wheel | T-Bar Crank/Rear Shackles | Hella 500 | No Sway Bar, Mudflaps, Valance | Dents, Scratches | 1990 Civic Si -Stock daily driver/gas sipper. |
#8 (permalink) | ||
Quote:
Quote:
I checked out the photo album that the picture Jay351 posted belongs to and it looks pretty good. You would have to have a sharp eye to notice that it doesn't match up perfectly. His kinda sticks out because the cab and bed are two different shades of black. Rob
__________________
#9 (permalink) |
I actually hope to make one fit so i can get the bestop for like 600 instead of the canback for 1k.
__________________
4.3/5.0 Do iT!
#10 (permalink) |
Ok new question! I found a mostly rust-free 2nd gen bed awhile back. I had to drive about 800 miles round trip to get it lol. So now I want to get a drop-in bedliner for it. I see a guy near here has one from a '91 6-foot bed. Mine is an '88 6-foot bed. Will it fit in mine?
Rob
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| xtra cab bed box/ long bed possible? | nomad | 84-85 Trucks & 4Runners | 13 | 10-08-2009 10:49 PM |
| 88 4x4 Xtra Cab | tacodriver | The Classifieds GraveYard | 3 | 09-29-2006 05:55 PM |
| 89 xTra Cab 4x4 SR5, Well built and great condition! | bryanr | The Classifieds GraveYard | 16 | 06-26-2006 02:04 PM |
| Xtra cab or regular cab frame | dixieduck | 86-95 Trucks & 4Runners | 4 | 01-13-2006 12:19 PM |
| 1987 Xtra Cab | Plays_with_Toys | Trucks, 2nd gen-'84 to '88 | 0 | 01-01-2004 10:06 PM |
