Will a 89 pick up truck ecu work in a 87 4runner?
Old 07-29-2010, 01:23 PM
strictly_s's Avatar
I have a 89661-35070 it says 22R when i have a 22R-E in my 4runner and I keep getting a code 11. I pull the plug from the tps and it still gets the same problem.
I have a 89 toyota pick up 4wd with a part number 89661-35160
Will it cause any damage to the truck or ecu?
Old 07-29-2010, 01:50 PM
89silverpu's Avatar
Not sure exactly, but there's a good chance it will work as long as the type of transmissions match, ie manual and a manual/automatic and automatic. I know that 87 ecu's work in 85's so you may be fine running an 89 in an 87. Here is a good link to search through:
http://www.4crawler.com/4x4/4R_TechInfo.shtml
Old 07-29-2010, 01:58 PM
strictly_s's Avatar
I looked at that already, the pin matches up both 4wd and manual. I'll try it in a bit and report back.
Old 07-29-2010, 03:44 PM
xxxtreme22r's Avatar
this question comes up alot, while they may seem to work, what you have to watch out for is the fact the sensors on the motor are differen't. ie different resistances in the AFM, injectors etc etc.
here is a photo of the ECU part numbers from the 4crawler site that 89silverpu was referring to.
Old 07-29-2010, 04:01 PM
myyota's Avatar
If the engine computer comes out of a manual or automatic, it makes no difference, the automatic transmission has its own seperate computer mounted below the radio in front of the shifter that controls the transmission.
Old 07-29-2010, 04:06 PM
by the looks of those part numbers it some years it does matter, it was my understanding the engine's ecu sends the signals to the trans computer as to what TPS and other signals are so the trans computer knows what to do.
Old 07-29-2010, 05:13 PM
89silverpu's Avatar
oh ok, thanks for clarifying that!
Old 07-29-2010, 05:17 PM
then why the different part numbers with A/T and M/T ????
Old 07-29-2010, 05:45 PM
strictly_s's Avatar
They both work in either trucks. My code 11 is from something else the ecu is fine since I got the 87 4runner ecu to run on my truck 89.
saphirekosmos
06-22-2015 10:26 AM
gog1968
06-22-2015 05:55 AM
paxanders
06-21-2015 06:29 AM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: Will a 89 pick up truck ecu work in a 87 4runner?
