who makes a 6 inch suspension lift??
Old 10-04-2011, 06:52 PM
superswamper003's Avatar
So ive seen many toyota pickups/4runners with a 6 inch suspension lift and i just want to know who makes that size lift? Thanks
Old 10-04-2011, 06:58 PM
87 Deathtrap's Avatar
Solid axle or IFS?
Old 10-04-2011, 06:59 PM
Its an IFS
Old 10-04-2011, 07:09 PM
Swimmerboy2112's Avatar
Let me ask you this, why do you want a 6" suspension lift?
Trying to fit huge tires?
Remember, the higher you lift, the higher it makes your center of gravity (COG).
With a higher COG, you are more likely to roll over.
Hence the reason I am going to try and fit 33's on stock suspension and my 86' can run 33's on only a 1.5" lift.
Just my .02
Old 10-04-2011, 07:17 PM
I just want it to sit high is all.
Old 10-04-2011, 07:20 PM
BMcEL's Avatar
Mall talk...pshh.
Old 10-04-2011, 07:28 PM
Swimmerboy is dead on. For real off road use, lower is better. If you just want to look cool, then maybe just pair a 4" suspension lift with a 2" body lift.
Old 10-04-2011, 07:30 PM
SR5
SR5's Avatar
well we can bash all we want...
but if you want it tall just buy any standard 4" lift kit, and add a 2" body lift.
and nobody makes a 6" ifs lift kit
Old 10-04-2011, 07:31 PM
SR5
SR5's Avatar
beat me to it..
Old 10-04-2011, 07:35 PM
BoredOutnJackdUp's Avatar
You could do a 4 inch bracket lift, 3 inch body and ball joint spacers. and with a little sawzall persuasion you could fit 49s....
SR5
SR5's Avatar
here:
suspension
http://www.roughcountry.com/suspensi...r_90-95_5.html
body lift
http://4crawler.com/4x4/ForSale/BodyLiftKit.shtml
Old 10-04-2011, 07:37 PM
SR5
SR5's Avatar
not a bad idea although sounds like a scary combo, and you would need 4" springs and 2" spacers for the rear
Old 10-04-2011, 07:45 PM
SR5
SR5's Avatar
although its pointless to lift a truck that high, i was on pirate 4x4 the other day, and theres a guy running 38" with no lift at ALL
Old 10-04-2011, 07:50 PM
i keed i keed.
The IFS would blow up. im running 33x12.5s with a 2 in. BL and love it.
gonna step up to 35s when i can.
oh and here's that
37s stock height
Old 10-04-2011, 08:52 PM
Hmm, so i could go 2 inch BJ spacers on a 4-5 inch suspension lift? And then maybe ad another 3 inches of body lift
Old 10-04-2011, 09:04 PM
malteserunner's Avatar
4" Bracket lift....
Blazeland LT....
6" Rear Springs...
Body Lift....
35x15.50-15 Tires....
Aloha!
Old 10-04-2011, 09:16 PM
Would the truck be level if i did the 4 inch bracket and the 6 inch springs?
Old 10-04-2011, 09:25 PM
With the added lift from the Blazeland Long Travel in front, it might.
yotarover's Avatar
boot to pirate they will take care of him.... im running 33/12.50/15's 2" bl no rubbing no nothing up front. no bed. if i had some 37's i'd run them the same way
Old 10-04-2011, 09:28 PM
lol seriously. They would be eaten alive.
Quick Reply: who makes a 6 inch suspension lift??
