white face guages for a 91 pickup
i have searched and looked all over ebay and cant find white guages for my 91 toyota pickup sr5 with a tach. Will the one for 4 runners fit. Tach and spedo in middle. oil pressure in top left, temp lower left, batterie in upper right and gas below that. I havnt even seen picks other other than in 4 runners. HELP PLEASE
exactly jay351 I noticed that also but forgot to mention it. thanks tho elton i seen that same thread that lead me to ebay. oh well mabye i will just tear it apart fix my low fuel bulb that has been burned out for 4 years and stick blue bulbs in there. anyone know for sure how many i thinks its 3 altogether
yeah, and when you tear em apart ... im not sure you can find blue bulbs that size... correct me if i am wrong, but the bulb is about as big as my wristwatch adjustment knob ... and it comes clear, and with a rubber green condom ... sooo. Let me know how you plan getting around that ... ill follow in your footsteps.
ITOYOTA: i just finished replacing they instrument cluster bulbs with blue ones. I seen the little ones that u were refering to. On my 91 pickup those little ones were just for the seat belt, 4wd, engine lite and brake lite and highbeam all down at bottom and those have there own individual clear bulb but the plastic the bulb lights up was colored itself so i left all those clear (example 4x4 is green, CEL is orange, seatbelt and brake are red) I only replaced the 3 bigger (194 bulbs) those were the 3 on myne that had the little blue condoms on. I will see tonite what it looks like when it gets dark
there not one piece you put them where there suppose to go to prove my point here you go https://www.yotatech.com/forums/f126/indiglo-gauges-1995-4runner-75768/
oh u can switch them around to match the pickup. so when i order them for my truck i will just have to order them as if they were for a 91 4-runner. am i correct?
three normal sized 194s, and then 2 smaller ones, one on each side, i just switched my bulbs out in my Surf....
how many bulbs are behind that gauge cluster, i want to replace all of the with LEDs and i need to know how many bulbs there are, (4x4, battery, brae, seatbelt, REVs speed, oil, fuel, temp, battery gauge, high beam, etc etc, how many all together?)
using different colored LED's with a spread pattern came up in a similar thread a while back...
http://www.superbrightleds.com/cgi-b...gi?product=CAR
steve miller
10-10-2015 01:40 AM
Kluch8651
07-09-2015 10:39 AM
