Where's your starter relay? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-08-2008, 01:04 PM   #1
Matt16's Avatar
I'm looking for the relay on a 1990 4Runner 4cyl 5spd specifically, but lets here where YOUR relay is no matter what *Toyota* you've got.
Automatics don't have a starter relay only a neutral start switch or something.
I want to know so I can (and you can) upgrade your OEM starting system. http://www.yotatech.com/f116/tech-ti...er-fix-160948/
Matt16 is offline   Reply With Quote
Old 12-08-2008, 08:58 PM   #2
Matt16's Avatar
Bump, I checked in the passenger's and driver side kick panels. I think its in there though did not find it. I can smell it. I'm almost certain it is not under the hood.
Old 01-13-2009, 09:37 AM   #3
Matt16's Avatar
Bump. I'm still looking for the relay. I'm near certain its not in the engine bay.
Old 01-13-2009, 10:06 AM   #4
rhale's Avatar
i believe in my 89 that its in the passenger side foot panel. i can hear it "click" when i turn the key to start it.
rhale is offline   Reply With Quote
Old 01-13-2009, 10:50 AM   #5
imike420's Avatar
In my '86 4Runner it is behind the passenger side kick panel.
imike420 is offline   Reply With Quote
Old 01-13-2009, 10:52 AM   #6
scuba's Avatar
Quote:
From the sounds of it that would be you Circuit opening relay...
Oh and matt, First sentence: http://personal.utulsa.edu/~nathan-b.../2starterr.pdf
scuba is offline   Reply With Quote
Old 01-13-2009, 12:24 PM   #7
Wile E. Toyote's Avatar
I did this fix and it worked beautifully. My relay is in the engine bay on the passenger side. Behind the fuse block. This is on an 88 p/u.
Wile E. Toyote is offline   Reply With Quote
Old 01-13-2009, 12:50 PM   #8
Matt16's Avatar
quote from FSM: The relay is located in the No. 1 junction block
on the driver’s side.
If I'm honest, I don't know what/ where that is.
Old 01-13-2009, 01:16 PM   #9
scuba's Avatar
Neither do I......
Lol, I forgot about that other thread as well...
Good luck on your search bro
Old 01-13-2009, 09:34 PM   #10
Matt16's Avatar
Found it:
Starter relay is surrounded by a red box on the parts screen. The relay is located in the driver's footwell.
The relay itself is a green box marked Toyota Denso Starter Relay. The relay is located in the driver's footwell (see the clutch pedal bracket and dead pedal?) above the fuse box.
voila. Looks to be a bit of a pain to get in there though to do the relay mod.
Most awesome reference ever. Thanks dntsdad.
http://www.toyodiy.com/parts/
Old 02-20-2015, 03:43 PM   #11
Hey I don't know if anyone can help me but if you can I would greatly appreciate it. I have a 1991 automatic 2-wheel drive 4Runner body that I put on a 1995 4x4 manual 4Runner chassis. I am to the point of no return on this lengthy project seeing as I went into it with my eyes closed. I am getting full electrical power to the cab but I can't say the same about my starter solenoid. I have checked the plug for the solenoid and it is hot but the solenoid makes no sound when I turn the key over. I also have no idea what wires translate over as the clutch safety wires so I have not been successful in reconnecting or bypassing that either. I am very frustrated and need a fellow enthusiasts help and guidance. If you know what to do about this please let me know. You can email me at [email protected] or you can call or text me at 541-601-2139. Any help would be appreciated. Thank you.
Operation4Skinner1.5 is offline   Reply With Quote
Old 02-20-2015, 04:04 PM   #12
hey bud you are new here, so let me give you a tip. Start a new thread, a lot of people might not respond too this because the title isn't really about your problem.
Schnayke is offline   Reply With Quote
Joe's 1987 4Runner ladybugRC 86-95 Trucks & 4Runners (Build-Up Section) 344 01-19-2017 12:41 AM
1999 4runner Won't Start zombie_barbarossa 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2015 11:54 PM
HELP! 89 4Runner 22RE Auto, no injectors! bradahman 86-95 Trucks & 4Runners 8 10-01-2015 10:24 AM
Weird Tundra Issues beltcutter Newbie Tech Section 1 09-30-2015 07:14 AM
Help! No start then No Power JPV Pre 84 Trucks 2 09-28-2015 04:15 PM
Tags
1987, 1990, 4runner, 87, 97, box, clicking, fuse, landcruiser, located, location, relay, runner, starter, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
