where are the terminals
Old 10-09-2007, 01:35 PM
surfmobile's Avatar
where are the terminals you need to jump when timing the engine? the chilton's book i have says its on the inside of the passenger fender but i don't see anything resembling what they have
Old 10-09-2007, 04:40 PM
mr toytech's Avatar
what kaind of truck do you have. it is usually on the pass fender somewhere under the hood. it is the diagnostic port, and i beleive it is e1 to te1. look for the diag. port neer the fuse box. it will be gray w/ a flip open top.
Old 10-09-2007, 05:19 PM
MMA_Alex's Avatar
on the fender right behind the battery. as stated above you flip up the top, on the inside of the top it will say which terminal is which.
Old 10-09-2007, 07:02 PM
BigWavePaul's Avatar
Exclamation Timing and Diagnostic Check Connector location(s) *linkies*
4Crawler.com
Pirate FAQ's
Old 10-10-2007, 01:52 PM
surfmobile's Avatar
i drive an 86 4runner. the only box on my passenger side is the main fuse box, that's why im so confused as to its location
Old 10-10-2007, 02:35 PM
surfmobile's Avatar
i found the terminals, and i *tried* to set the timing at 5. it would only get to 8 before i had to change the alignment to the camshaft, not whe won't even start? i'm confused
Bourbonblues
12-15-2017 05:43 PM
dbollier123
09-29-2015 05:23 PM
runnermedic
13
09-21-2015 05:20 PM
some drunk guy
09-04-2015 11:55 PM
terminator
07-27-2015 07:13 PM
Quick Reply: where are the terminals
