Where is the plug to Read codes with The Code Reader
Old May 3, 2008 | 05:01 AM
simpsons721's Avatar
Wink Where is the plug to Read codes with The Code Reader
hey
i have no idea where you plug the code reader in a 94 4runner just wondering so i can diagnose some problems
Old May 3, 2008 | 05:08 AM
bigt's Avatar
actually you jump a terminel in the diagnois port and you count the check engine blinks..has a built in computer ill look up what ones to cross
Old May 3, 2008 | 05:12 AM
will the people at autozone do this for you??
Old May 3, 2008 | 05:14 AM
bigt's Avatar
no you can do this its so easy man..
get your self like 2 inches of wire... strip both ends
now open your hood.. look to the left above batter where you see diagnois.. flip up the black cap and put your wire in T and E now turn the car over to on but dont start it and count the blinks!
Old May 3, 2008 | 06:25 AM
js9924's Avatar
the terminals you jump are actually TE1 and E1 the box is right next to the fuse box probably behind the battery it does say diagnosis on it. There is a drawing of which terminal is which on the inside of the cap. Then put key to on and count the blinks.
Old May 3, 2008 | 06:53 AM
mt_goat's Avatar
They will if your vehicle has OBDII, but that didn't start until 1996.
More on that:
http://www.obdii.com/
smthwsn357
May 1, 2024 07:28 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
