Where to get bushing for the 555 idler arm
Ive attempted to use bushing from the dealership "19mm" but they are about 1mm to small. I have some on order from AZ so ill find out about them tomorrow at 3.
From what ive found 555 idler arm came from AZ selling them for the 4wd pickups even though its for the 2wd. i measured 20mm on the shaft. maybe 19.5mm as stated on 4crawler.
oh man.. i may just try to dremal out the 19mm bushings I have. or sense its the hung unicorn everyone wants maybe ill flip it and just put a cheap one in for now. I need to get this thing back on the road.
I believe the "legend" was the Duralast idler arm, which was the thickest one.
I would personally just slap a cheap idler on there temporarily and contact one of the vendors and see if you can get a set of brass bushings for your Sankei idler. Then they'll never wear out.
true, that is the currently plan. Now just for what cheap idler arm to pick? napa o'ry-hole AZ or advanced?
I saw someone mention napa makes a alright arm but im probably going to lowest dollar
Napa has a Rylock 190101 for $36.47
AZ has one for around $40 to but from what it sounds like that one is real piece of ˟˟˟˟.
O'ry-hole masterpro j9424 $19.46
advance moog $149 beckarmly $147
ok dont get the masterpro. its going back in the morning (wasted my grease and time). You will strip the castle nut before the hole lines up for the cotter pin.
Napa tomorrow.
Napa tomorrow.
