Where are the fuses for the back window - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-04-2007, 07:34 PM   #1 (permalink)
Just got my 88 4 Runner back from the 3rd owner. I was the second and now fourth owner. Long story. 255,000 miles..does not leak or use oil..3.0 and has lots of power. Anyway it came back with the inside switches for the back window not working. Where are the fuses or could it be something else? How often does the timing belt need changed? Where can I get a tonneau cover for the area behing the back seat..when the top is off. By the way I love the forum. She came back to me with the brake and alt lights on..after reading some threads I checked the alt. brushes-which were fine- then cleaned up the ground wire off the battery and everything was good to go. Thanks all...all thoughts are appreciated.
yotaknows is offline
Old 02-05-2007, 03:45 AM   #2 (permalink)
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
There is relay box behind the panel in the passenger cab behind the driver's seat that may be faulty. First, you might check the switch in the console. Does it work with the key in the tailgate? There are threads that go into how to start tracking down the issue in your electrical system. I found them when my rear window stopped working. After trying to replace the relay switches on the little circuit board behind the seat, I wound up just bypassing it with a new switch.
The timing belt? Don't know...I'd call the dealer for general recommendation. But, you can also do a search on that. I've just not had to replace one yet.
The tonneau cover? Sorry, can't help you with that. I know there are even threads on that I've found, but I don't remember keywords for finding them.
__________________
Matthew
Context is everything....
Quote:
Originally Posted by abecedarian View Post
freckles, shmeckles... that was your acne reflecting on my pearlescent skin.
Get smacked....join chat!
http://www.yotatech.com/misc.php?do=flashchat
thook is offline
Old 02-05-2007, 11:22 AM   #3 (permalink)
Thanks I will check the switch first. Appreciate your input.
Old 02-05-2007, 01:51 PM   #4 (permalink)
Mudlover's Avatar
Quote:
Check under the kick panel near the left foot. There are 2 breakers with yellow covers with a hole throught the yellow cover. I had a problem that the breaker tripped. I pulled it out and used a paper clip to reset the breaker. You might try that.
The timing belt I believe is every 90,000 mile. But don't quote me on this.
Is this the top you are looking for?? http://www.specialtytopco.com/images/4runlg.jpg
Their web site - http://www.specialtytopco.com/
__________________
86 Chevy El Camino 4.3, Soon to be a 350 twin turbo charge ride.
2004 Peej Cherokee
2002 Sequoia
Mudlover is offline
Old 02-05-2007, 03:58 PM   #5 (permalink)
4runnerx3's Avatar
First thing to check is the top bolts. The bolt behind the driver side rear wheel has a kill switch under it that kills the operation of the rear window.
4runnerx3 is offline
Old 02-05-2007, 09:28 PM   #6 (permalink)
So the kill switch is located under the bolt....do I have to take the top off. third owner took the top off..first time it had been removed..could this have messed with the switch?...thanks for your input
Old 02-06-2007, 08:33 AM   #7 (permalink)
I looked in the back compartment and found the wire connection to the wiper was unhooked. Put them together and everything works. Thanks for the help. I really think this kind of website is the wave of the future. Everybody working towards a common goal. Not just cars but lots of issues could be resolved. Thanks
Old 02-06-2007, 09:06 AM   #8 (permalink)
4Crawler's Avatar
See this page:
- http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Auto UP window goes up, then back down? eng208 95.5-2004 Tacomas & 96-2002 4Runners 12 10-17-2006 04:39 PM
Stuck back window Toyotallyinsane 86-95 Trucks & 4Runners 5 03-28-2006 12:46 PM
back window problems jtm994 95.5-2004 Tacomas & 96-2002 4Runners 12 12-14-2004 11:43 AM
Shaking Back Window 4x4Fink 95.5-2004 Tacomas & 96-2002 4Runners 10 11-15-2003 09:42 PM
2009 InternetBrands, Inc.
