Where is the fuel pump wire?
The procedure for relieving fuel pressure to service the fuel system says to disconnect the wire to the fuel pump. I can't find the wire though. Where's it at?
You don't have to relieve the pressure, just be carefull to loosen the lines slowly. Put a pan under the filter as some gas will run out. Also loosen the gas cap so any pressure in the tank doesn't push the fuel out the open line. Wear safety glasses just in case, gas stings in the eyes.
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
