Where to find a switch for dash knock out
Old 11-09-2015, 12:25 PM
Pumpjack's Avatar
Has anyone found a switch that will fit right into the blank spots in the dash that have knock outs. A switch similar to the clutch start cancel would be ideal but a toggle would work also. I am putting in a light bar and didn't want to drill a hole in one of the knock outs, but rather have switch that fits like the factory switches, if that makes sense.
Old 11-09-2015, 12:30 PM
uncleblues's Avatar
The switches from a center console will fit. I moved my rear window switch to the dash, tapped power from the rear window breaker to a pair of 12 v relays. What are you switching?
Old 11-09-2015, 12:33 PM
uncleblues's Avatar
Oh, a light bar.
Old 11-09-2015, 01:12 PM
RJR
RJR's Avatar
I found a switch at Autozone that was a direct fit. Unfortunately it was a push-push design with some fancy electronic logic that was incomprehensible and unreliable, so it wasn't very functional for my purposes. Looked pretty, though.
Old 11-09-2015, 01:40 PM
scope103's Avatar
VERY generically that form factor is called a Contura switch (I believe the name Contura is owned by Carling, so you could probably find a knock-off if you're price sensitive.)
You can try https://www.otrattw.net/ ; they have all sorts of labels for anything you could want. Or just google "Contura."
Old 11-09-2015, 04:23 PM
highonpottery's Avatar
there are lots of universal "push button" style switches available if looking for something that's not the "contura" style. most seem styled more like the switches in the newer toyotas where there's no trim behind it, the button fills the entire hold vs the clutch start cancel- style with a trim around the edge. best bet might be to find one you like in a google image search.
Old 11-10-2015, 06:25 AM
Pumpjack's Avatar
Okay so the switches from 0trattw.net will fit? I measured a knockout against the measurements listed on the site, they are close but not the same.
Old 11-10-2015, 06:48 AM
scope103's Avatar
Sorry, I've never actually tried them. Do let us know what you find out.
Old 11-21-2015, 04:47 AM
uncleblues's Avatar
I've modified the console switches. Used a rear window switch for a starter switch once. You could use, for instance, the rear wiper switch for your application. Find the wires that show continuity with the switch in the on position. Tap one wire into a 12 v source. Since you're in the dash the cig lighter will do. The other wire goes to a 12 v relay to trip the lights. Tap into the alternator output, fuse it and into the relay, out to the light bar.
Old 11-21-2015, 07:16 AM
BigAxeJack's Avatar
There are lots of Toyota switches that will fill that blank. I'm thinking a push-on push-off switch would serve you best. Like a hazard or defrost switch from any 80's-90's Toyota car or truck. Use your ohm meter to find the wires governed by the switch, then follow the wiring example posted above. You can find one at the local junkyard or pull-a-part if you have one close by. You can find them on ebay. Also there are plenty of used parts dealers like YotaYard, CruiserYard, Yota Jim, Cruiserparts, etc.
The following users liked this post:
Meatbag (11-09-2022)
Old 11-22-2015, 07:19 AM
80seriesftw's Avatar
I have a few switches that id sell cheap.
Pm me
Old 11-23-2015, 06:08 AM
Brock Lee's Avatar
I have been thinking the same thing. I just bought some auxiliary lighting and I'd like a switch that fits the blanks also. I'm thinking this one, might?
This one looks like it would work, but I don't own it. I'm also not sure how I'd wire it up when I got it, IF I got it. This was on eBay recently.
Old 11-23-2015, 07:08 AM
It will work. You will need the pigtail harness that it connects into though.
Old 11-23-2015, 11:18 AM
Pumpjack's Avatar
I think I found what I need. I will post when I get it done.
Old 11-23-2015, 11:36 AM
don't forget to add a relay if you're switching something that draws a decent amt of power
Old 11-23-2015, 11:43 AM
Brock Lee's Avatar
Perhaps this one will work?
Old 11-23-2015, 12:18 PM
Btw I have a few switches like that with the pigtail for sale
Old 11-23-2015, 04:29 PM
Brock Lee's Avatar
Thanks for the offer, bro. I bought that first one I posted off eBay though. $15 and it'll be at my doorstep just after Turkey Day. It will go into the blank spot in the image below I'm hoping.
Old 11-26-2015, 05:54 PM
Nice man! It will look factory!
HiDesertLux
11-28-2020 12:26 PM
thewhitestallion
10-11-2015 11:40 AM
90YotaPU
09-21-2015 05:58 PM
mdh
09-15-2015 12:12 AM
86 87 4Runners
09-03-2015 02:35 PM
Quick Reply: Where to find a switch for dash knock out
