Where does your oil pressure needle sit at?
Old 07-13-2008, 02:54 PM
Rebel's Avatar
Just did an sr5 cluster swap and I am just curious where evryones oil pressure sits at. After being warmed up my needle sits about 1/8th inch below the 1st dash. While driving it sits at half.
Old 07-13-2008, 02:59 PM
Dublin's Avatar
That's exactly what mine has done for the last 14 years and 268,000 miles. I stopped worrying at about 87,000.
Old 07-13-2008, 03:03 PM
toyotatom93's Avatar
Mine will sit at pretty much zero while idling and about 1/4 while driving.
Old 07-13-2008, 03:04 PM
Jay351's Avatar
0, reguarless of engine rpm after its warmed up. Huzzah for accurate guages!
Old 07-13-2008, 03:06 PM
SHOrunner's Avatar
So, should I be worried that mine just started reading zero after my oil change an hour ago? It's running the same, new plugs and wires too. Do these gauges just stop working all of a sudden?
Old 07-13-2008, 03:08 PM
crews462's Avatar
My oil gauge does the same, low at idle, half while driving
Old 07-13-2008, 03:09 PM
Jay351's Avatar
Did you switch oil brands or weight? Filter? If it was truly 0, you're engine wouldn't be running..
Old 07-13-2008, 03:17 PM
SHOrunner's Avatar
Nope. Same brand, same weight as before. Different filter though. Where is the sender located?
Old 07-13-2008, 03:21 PM
Jay351's Avatar
Right beside the oil filter
Old 07-13-2008, 04:55 PM
SHOrunner's Avatar
Huh. Nothing hanging, but I might have pulled on the wire a bit when changing the filter. Everything runs the same, so I'll just ignore it for now.
Thanks anyway.
Old 07-13-2008, 04:59 PM
nix4x4's Avatar
These trucks are notorious for bad oil senders.
Just keep you oil changed and filled to the appropriate level, no worries
Old 07-13-2008, 05:11 PM
bigt's Avatar
my dd with a rebuilt engine has lower oil pressure on the gauge and my
trail rig which my family owed since almost new has really high oil pressure..
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Where does your oil pressure needle sit at?
