Where does this wire at the fuel rail go?
Old 07-14-2012, 04:17 PM
flatbed's Avatar
Putting motor back after doing head/timing chain job. The wire in question comes out of the harness around #3 & #4 injector plugs at fuel rail. It is thick with three brown wires and has an eye conector for a bolt to mount through. I labeled it, but the tape to it's buddy must have come off over the past month since starting. Thanks, would post pic but camera is a pain right now.
Old 07-14-2012, 05:11 PM
myyota's Avatar
Im guessing here, but it sounds like it might be a ground wire that bolts to the intake ?.
Old 07-14-2012, 06:15 PM
arlindsay1992's Avatar
The camera might be a pain, but so is a motor you can't put together. Help us help you. A picture will make it easy to say for sure. If it just has an eyelet at the end it's probably a ground.
Old 07-14-2012, 06:20 PM
neb21's Avatar
This.
Old 07-14-2012, 07:49 PM
abecedarian's Avatar
Three brown wires into a ringlet?
Ground connection.
Old 07-15-2012, 07:37 AM
flatbed's Avatar
Yeah, thats it. I found some old photos from when I replaced the harness last year and it's the ground wire to the intake. -Thanks guys
Old 07-15-2012, 07:44 AM
flatbed's Avatar
One other wire is a 7inch black/yellow ground that is mounted to firewall between heater hoses and has an eyelet on other end. Does the unconnected end go to back of rockerarm cover? All my labels have come off since the start. Thanks
Sleaker
08-26-2020 06:03 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
v_man
07-23-2015 04:01 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Where does this wire at the fuel rail go?
